Drive shaft - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-02-2015, 10:45 AM Thread Starter
Drive shaft
I need some help my 05 Gto is starting to shake when I take off from a dead stop once I pick up speed it stops
Gto x is offline
post #2 of 5 (permalink) Old 04-02-2015, 04:38 PM
Check your guibos and center carrier.
post #3 of 5 (permalink) Old 04-02-2015, 07:16 PM
pocketmaster's Avatar
Yyyyep....check your carrier bearing. This is what mine looked like.....
God Bless Billiards!!!!
pocketmaster is offline
post #4 of 5 (permalink) Old 09-20-2015, 04:00 PM
Yup carrier bearing for sure mine does the same thing you describe the rubber piece around the bearing is worn out
You have a few options
1 get a 1 piece driveshaft from driveshaftshop.com for about 680
2 buy a new center carrier bearing from gtog8.com for 120 and if you feel you can replace it your self go for it you can search the forum and find out how to do it. I've found it once before but not sure where
3 find a used 2 piece on eBay... But I wouldn't recommend it
Now my opinion I would do and I myself plan on buying the 1 piece driveshaft from driveshaft shop. Reason being is because the drive shaft is the weakest link in our drivetrain and is a great investment
zmartin07 is offline
post #5 of 5 (permalink) Old 09-23-2015, 04:39 PM
HP11's Avatar
Quoted: 24 Post(s)
Doubt that he'll see your advice. That was his one and only post and he hasn't been back since three minutes after he posted it.
HP11 is offline
Drive Shaft MATTJ Drive train, suspension, alignment and brakes. 1 03-21-2015 10:26 AM
Drive Shaft funbooker 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-24-2013 07:14 PM
drive shaft? hemi1282 Service, Maintenance and Technical Discussion 6 10-21-2013 08:11 AM
drive shaft mikey9743 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2013 08:56 AM
Drive Shaft Stamp235 Drive train, suspension, alignment and brakes. 5 07-29-2007 01:43 PM
