Driver's power seat issue, 2005 GTO. - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-25-2017, 11:53 AM Thread Starter
Al52's Avatar
I purchased a near mint 05 GTO last year, 26,000 miles. The driver's power seat functions all work properly except for the forwards and backwards movement. It moves back and forth but only for a limited distance as opposed to the passenger seat, requiring a full extension of the leg to depress the clutch. Kind of rough on a 65 year old damaged knee joint. I unhooked the battery hoping for a reset, zip. Checked for blockages under the seat, zip. I'm now wondering if the actual power seat motor is at fault here. I would most appreciate any suggestions as what may be going on here and how to best address it.
Al52 is offline
post #2 of 5 (permalink) Old 06-25-2017, 05:59 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
time 4
time 2 pull it out and flip it over on the bench .......
and play with it .....
buy another seat track b4 you pull it and swap em out
parts will cost as much as another seat track ...
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 06-25-2017, 08:07 PM Thread Starter
Al52's Avatar
Thank you. Guess I'll yank it and give it a go.
Al52 is offline
post #4 of 5 (permalink) Old 06-26-2017, 08:48 AM
GTO44's Avatar
Quoted: 37 Post(s)
If your seat is working just for a limited amount of travel, I would check the track and make sure it's not binding anywhere.
Typically if the motor goes or the switch goes you won't have any movement.
If it is the motor or the rails are bent and you can't fix it, get something like this. Basically plug and play: https://www.ebay.com/i/371821005511?chn=ps&dispItem=1
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #5 of 5 (permalink) Old 06-30-2017, 12:41 PM Thread Starter
Al52's Avatar
Appreciate the advice. Thank you.
Al52 is offline
Help With Power Driver Seat Mathew Sokos 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-10-2017 02:37 PM
Difficulty removinG driver bucket seat in 67 GTO Mathew Sokos 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 10-09-2016 10:24 AM
2005 GTO Driver's Seat Moves by Itself YELLOGTO Service, Maintenance and Technical Discussion 2 07-24-2011 08:24 AM
Power Windows, Power Locks, Seat Belts, Power Rear View Mirror, Back Speaker Location GQUINCOCES 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-03-2009 07:18 PM
