Driver's Side Seat - Pontiac GTO Forum
 1Likes
  • 1 Post By GTO44
post #1 of 3 (permalink) Old 05-03-2017, 08:57 PM Thread Starter
Driver's Side Seat
The driver's side seat on my '04 has stopped moving forward and back. The seat back tilts using the power switch but the seat won't move forward or back using either switch. I've disconnected the battery, checked the fuse with no good result. I'm afraid the motor may have gone bad.
Any thoughts?
Thanks,
mitch
bemitchellwdw is offline
post #2 of 3 (permalink) Old 05-03-2017, 09:11 PM
GTO44's Avatar
Quoted: 37 Post(s)
You can try putting a 12volt source directly to the connector for the motor and see if it moves either way. If it moves you know the switch went bad. If it doesn't you know the motor is toast.
I actually just did that last night helping a buddy out with his older 5.0. His seat goes up and down but not forward or backward. We took the 12 volt source coming from wiring harness, rigged up a couple wires, and applied it directly to the seat motor. The rails on the seat immediately started moving so for what ever reason the forward/backward part of of the little joystick control had gone bad.
Goat Roper likes this.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 3 (permalink) Old 05-03-2017, 09:14 PM Thread Starter
Ok. Thank you for that! I'll give that a shot this weekend.
Rear Driver's side seat belt stuck Rauq Service, Maintenance and Technical Discussion 4 10-26-2010 01:49 PM
Driver side window fhkt1 Interior Discussions 1 12-20-2009 01:22 AM
