drivers side squeak - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-14-2014, 08:16 PM Thread Starter
drivers side squeak
so this is very broad. i have a squeak coming from the front drivers wheel well. ive determined it isnt in the engine simply because it squeaks when im not driving or when the engine is running. i jacked up the front corner and shook the tire and nothing.
like i said i know its very broad, but i was wondring if you guys had any place in particular i should start looking, besides just naming every component of the front end.
since i seem to hear it when the car is rocked (like when i shut the door) i think thats where i might start. this weekend if i get a chance ill pull the tire and check the spring. see if the coil is rubbing on anything. like i said, im just wondering if there is somewhat of a known problem for anyone else that would save me some time. thanks
2006 m6 phantom black GTO:
kooks long tube headers
kooks cat-less mids
bassani cat back
ripstick
lingenfelter intake
BMR drag Bags
The Black Mongoose is offline
post #2 of 2 (permalink) Old 10-21-2014, 08:38 AM
Strut bushing and bearing is fairly common
Removing Drivers Side Window pocketmaster Service, Maintenance and Technical Discussion 14 04-22-2016 06:04 PM
Lean to the Drivers Side on the 64 pbearly 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 12 05-18-2014 12:49 PM
Drivers side window regulator pocketmaster 2004-2006 GTO General Discussion 4 01-05-2011 06:07 PM
Drivers side window GTO_Mike Interior Discussions 3 08-09-2006 02:57 PM
