Dynoed my 04 today - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-20-2005, 08:27 PM Thread Starter
rushhour's Avatar
Dynoed my 04 today
Before I start - I know this thread sucks with out a picture of the dyno chart -cant post it until Monday since I don't have a scanner here.
Now - there was a trailer dyno up at Etown today - Dynojet. I didn't plan on doing anything but spectating - since it was EVO vs WRX day. Any event decide to try out the dyno. The car was hot, hot, hot. The MAF tube next to the IAT felt as if it was well over a 100 degrees - so I figure the IAT was going to pull some serious timing (airtemp @ ETown was at least 85-90 degrees and humidity was at least 75% - another useless summer day in Jersey). Figured it was worth a shot see what a hot car would put down.
Bottomline is 2 runs (no cool down) - not great but
Max HP 281.8 & 282.2 (held 275 & up from 5200 to 6000 cut off)
Max TQ 316.4 & 312.1
A/F (sniffer in on tail pipe) - 12 to 12.3 except for a 11.5 around 3800 rpms.
Since this is the first time that I have put the car on a dyno - I assme the figures should have been a lot better if the IAT wasn't pulling timing all over the place.
Got about 7,800 miles on her right now.
Just to see how long the IAT stayed hot - I went out after an hour when I got home and checked the IAT temp with the preditor. About the same time it sat at ETown with the hood closed. It is about 10 degrees cooler at my house and the IAT was still recording 130 degrees - so I figure it pulled a few degrees of timing when we dynoed it.
Gotta love black cars sitting in the sun - could fry an egg on that hood right now.
Next week ETown is having one of their GM EFI days - we will see what the times are. If they are way off my best of 13.57 - I am going to start trying figure out what the issue is.
Setup is:
2004 GTO Phantom Black, A4, Pedders Cross member Bushings, SLP sway & end link bushings, Koni Rears, RWTD Tune, Shaner S1, HSV 300KW tube & Monaro 2 hole CAI. Stage 1 Sports Appearance Package
13.57 full street trim with just tune, tube & cross member bushings
2004 Black, A4, (aka the Black Demon)
390ci AES low compression
PB 1.611, 11.732 @ 115.22, DA +1,973 @ 4,005 lbs
1.566, 11.585 @ 116.22, DA +960 @ 4,010 lbs (Nasty Headwind)
1.538, 11.352 @ 119.16, DA -2,340 @ 3,960 lbs
rushhour is offline
post #2 of 3 (permalink) Old 08-22-2005, 10:16 AM
Setup is:
We have come up with a wheel hop solution, email me at [email protected], we can go over a couple or options...
GTODEALER is offline
post #3 of 3 (permalink) Old 08-22-2005, 05:55 PM Thread Starter
rushhour's Avatar
Thanks GTODealer - will do, anything to "Stop the Hop" (Pontiac's new theme song)
Sent my dyno chart over to James & John @ RWTD - John said that the A/F needs a little adjustment. Should have a new tune in a day or so (just in time for Etown saturday). Told me also not to get too crazy about the HP & TQ numbers given the heat soak/humidity and the fact that it was a trailer dyno. The important piece was that I finally got an A/F for them.
Love these guys
Can't post the actual PDF file for some reason. Will try to do it in the gallery
rushhour is offline
