E brake Light flashes on and off - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-12-2013, 03:39 PM Thread Starter
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
E brake light decided to stay on one day. The e-brake is not activated. I had tire kingdom check the sensors and brake levels and they are all fine. What do you guys think it might be. Also it will flash on and off when ever I hit a bump. Also it will turn off if im taking a slight bend on the interstate. A friend told me it was the electrodes on the float in the brake reservoir. Thank you for your time and help
Gto-noob is offline
post #2 of 4 (permalink) Old 10-12-2013, 05:22 PM
I believe there's a switch for the e-brake. Are you sure it's not just a brake light? If so check your brake fluid reservoir. If it's low fill it and as soon as you can check for worn pads or bad lines.
post #3 of 4 (permalink) Old 10-12-2013, 05:45 PM Thread Starter
what do you mean by just a brake light? all my lights work. my reservoir was a little low the other day and I refilled it (which was a week back) it has not changed level. I also had History codes saying the reservoir was disconnected and re connected so im lthinking that the sensor at the reservoir being bad?
Gto-noob is offline
post #4 of 4 (permalink) Old 02-03-2015, 07:11 AM Thread Starter
Update**** was a bad ground.
Gto-noob is offline
Brake light on? Darth Menace 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 8 09-04-2013 10:52 AM
Brake/tail light HELP Thejudge 69GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 03-29-2012 07:31 PM
headlights dim when turn signal flashes on xcmac26 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 26 12-21-2009 05:28 PM
Brake Light? primerGTO Service, Maintenance and Technical Discussion 1 12-17-2006 08:21 PM
