Easy Way To Raise Rear Of Car? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-05-2005, 10:07 AM Thread Starter
I would like to raise the rear of my goat 1 inch in the back. Any ideas?
tiresmoker is offline
post #2 of 3 (permalink) Old 03-05-2005, 03:02 PM
anmracing's Avatar
Why do you want to rake it? I don't think any one makes lift springs for cars. You may need to use those little spring speader thingies they sell at Pepboys. They're not recommended but they will lift the car a little....
It would probably be easier to get lowering springs for the front.
anmracing is offline
post #3 of 3 (permalink) Old 03-08-2005, 11:16 PM
b_a_betterperson's Avatar
Thought about that myself. Actually, at certain angles, the gap over the tire on a GTO looks narrower than the front. Got the tape measure to check -- and it's an illusion.
That said, you could, in theory, install new springs or try different combinations of spring rubbers. However, by raising the car, you're going to modify the geometry of the rear suspension -- so you might need an alignment. Also, you'll be putting a slight amount of stress on the IRS universal joints -- which may cause them to wear prematurely. As anmracing pointed out, you're much better off dropping the front a half inch or so...
Good luck!
b_a_betterperson is offline
