ECU "relearn" - Pontiac GTO Forum
post #1 of 10 (permalink) Old 05-17-2005, 10:00 AM Thread Starter
ECU "relearn"
How long does it take the ECU to "relearn" after installing a CAI ?
gameover is offline
post #2 of 10 (permalink) Old 05-17-2005, 10:05 AM
A while, you can reset it by putting the key in the run position and pull the red fuse in the engine bay fuse box for about 30 sec.
AmesGTO is offline
post #3 of 10 (permalink) Old 05-17-2005, 11:09 AM Thread Starter
Can't I just disconnect the battery?
gameover is offline
post #4 of 10 (permalink) Old 05-17-2005, 11:16 AM
If the key isn't in the run position disconnecting the battery won't get the PCM to reset what it has "learned". You can put the key in run and disconnect the battery, but pulling the red fuse is much easier.
AmesGTO is offline
post #5 of 10 (permalink) Old 05-17-2005, 12:53 PM Thread Starter
AmesGTO,
Thanks for the info!
gameover is offline
post #6 of 10 (permalink) Old 05-17-2005, 12:59 PM
Sooo, kiddees...the ECU or PCM will not relearn a CAI PDQ, if not ASAP. If not, you're SOL, and that's decidedly NFG.
Groucho is offline
post #7 of 10 (permalink) Old 05-17-2005, 02:11 PM
i dont understand this computer stuff, will it or will it not learn to adjust for the extra air flow?
ouijaguy is offline
post #8 of 10 (permalink) Old 05-17-2005, 02:16 PM
I don't know what Groucho is saying either. The Aussies do the red fuse re-learn procedure a lot (at least that's what I've read). Good for a little performance boost before drving hard.
AmesGTO is offline
post #9 of 10 (permalink) Old 05-17-2005, 04:51 PM
will this work on the new LS2 engine? I have a custom intake that allows more air than the K&N and the NewEra, when we were testing it the ECU/PCM sensed the extra air and just started dumping in extra fuel to make up for the extra air. Does this somewhat work inplace of a tune until one can be proformed?
Braman'sGTO is offline
post #10 of 10 (permalink) Old 05-17-2005, 04:56 PM
It seems to be a pretty universal thing for GM so I'd guess it will work on an LS2. The red fuse part might be 04 only I don't know (it's really just an easy way to kill power to the PCM only). But the put the key in run and unhook the battery is very universal to GM.
It's not going to be anything nearly as good as a tune. I'd think of it more like getting rid of the cars bad habits.
I read a lot about this on the Aussie boards a year ago. A guy also put up a page about it here: http://www.mytired.com/cars/index.htm?page=car_rset.htm
AmesGTO is offline
