Electronic throttle hesitation - Pontiac GTO Forum
post #1 of 18 (permalink) Old 02-02-2011, 06:52 PM Thread Starter
I have a 06 gto its had what I would call a pretty signifigant hesitation from when you step on the gas to when the engine roars its not giving any codes. I tried cleaning the throttle and throttle body thats ok and is working fine. has anyone noticed that or had that issue resolved. I don't have anything to compare it to other than a 07- Z06 vette I was in drivers seat working the gas pedal. the electronic throttle on that was dead on just instantaneous response from pedal to engine. I'am not saying my $30 pontiac should be a $70 Z06. I just dont think its right or working properly.any help would be great thanks. Its the same cold or hot.6spd didn't know they made auto
sheldon is offline
post #2 of 18 (permalink) Old 02-02-2011, 08:30 PM
Mike_V's Avatar
Is your GTO an auto?
Mike_V is offline
post #3 of 18 (permalink) Old 02-05-2011, 04:27 PM Thread Starter
6spd 24000 mi I cleaned throttle body again but sprayed a little white lith at hinge points of throttle it seems a little better it still seems off though sheldon
sheldon is offline
post #4 of 18 (permalink) Old 02-11-2011, 08:13 PM
87GN06GTO07IRL's Avatar
clean the maf also
87GN06GTO07IRL is offline
post #5 of 18 (permalink) Old 02-14-2011, 12:16 PM Thread Starter
Cleaned MAF sensor when I cleaned the throttle body & there is still hesitation. Maybe I should order electronic throttle for a same yr Z06 if it fits. I'm sure its cost prohibitive being an upgraded performance version Corvette. That alone makes it three times more at least.
sheldon is offline
post #6 of 18 (permalink) Old 02-14-2011, 01:44 PM
Mike_V's Avatar
Do you have anything you can monitor with? Maybe you're getting knock, maybe your throttle is not registering WOT. You really need something to monitor what's going on. If nothing else, take it for a tune before guessing at stuff.
Mike_V is offline
post #7 of 18 (permalink) Old 02-20-2011, 01:43 AM
I have the exact same problem sheldon. I have an 06, manual, only 10k miles, and since the time I bought her she has had the same hesitation you described. It's like there is a lag between when the ecu registers throttle pedal movement, and when the ecu starts moving the throttle blade. Easiest way to explain it is the ECU is sampling to slowly. Nobody else has noticed? Snap the throttle and you will notice it's not crisp. Would love to know how to fix this.
boostinallovryou is offline
post #8 of 18 (permalink) Old 02-23-2011, 05:51 PM Thread Starter
How much is a tune & who does a good job ? I've seen a HP Tuners VCM Suite Tuning& Scanning Tool for around $500 would it be economical to buy one of these verses taking it in somewere. Is that a good brand tuner & or price or can anyone recomend something else I think if I take it in somewere its going to cost alot Im a old school mechanic never got into much of computer stuff for cars and Im a hack hunt n peck on my laptop sometimes wanting to just smash the thing! So are these tuners user friendly or what ? Boostinall I'll let ya know when I figure it out
sheldon is offline
post #9 of 18 (permalink) Old 02-23-2011, 10:56 PM
You mean, have a look at live data. Even TPS can be off... if I remember correctly HPT registers stock TPS output some where beteween like ~6-88%, but the claim is that full 5 volt signal is a PCM reference to see if the circuit is working...
Poncho Dan is offline
post #10 of 18 (permalink) Old 02-23-2011, 11:53 PM
GM4life's Avatar
Not a 100% shure, I think the throttle response can be adjusted thru HPTuners. My wifes G8 is the same way with the delay. I've driven 6QTS11OZ's GTO and his throttle response is instantous.
GM4life is offline
COLD hesitation / stumble rcubed3r Service, Maintenance and Technical Discussion 4 02-02-2010 01:44 PM
electronic cut out mr.gto Intake and Exhaust Discussions 5 11-28-2009 01:51 PM
67 gto hesitation javamon 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 10-06-2008 04:06 PM
Electronic throttle control problem Ole school muscle Service, Maintenance and Technical Discussion 3 01-18-2008 10:25 AM
Electronic Supercharger dizzy1 2004-2006 GTO General Discussion 8 05-09-2007 06:33 PM
