Engine Fire... Every late model GTO owner should read. - Pontiac GTO Forum
post #1 of 9 (permalink) Old 08-06-2010, 12:49 AM Thread Starter
I didn't see anything on this site about this, but it seems to be a very dangerous and widespread issue. Please check out the link at LS1gto.com
F. M. L. -- another potential Fuel Rail Cover Fire - LS1GTO.com Forums
It seems the fuel rail cover on the driver side is rubbing against the fuel line. In extreme cases this rubbing has caused a hole in the fuel line, leading to a fire causing a total loss. I checked mine last night and sure enough there is a knick on the fuel line. I called Pontiac customer service at 1-800-762-2737 and talked to them. There isn't an active recall at this time, but the guy said if enough people call in that have this same issue it will help speed up the process of them issuing it. I'm am going to write up an email and submit it to them as well as a copy to NHTSA. If you would like to be part of this email maybe we can get a recall issued.
ChrShaDil is offline
post #2 of 9 (permalink) Old 08-06-2010, 07:09 AM
HP11's Avatar
Quoted: 24 Post(s)
This is old news. If you've been around these cars for any length of time you'd know about it. I wouldn't hold by breath waiting for GM to institute a recall. Mine actually wasn't rubbing (28K mi.) but I sleeved it in that area just for peace of mind. And, no, not the 'ghetto' rubber hose cover that they discuss in that thread...
HP11 is online now
post #3 of 9 (permalink) Old 08-06-2010, 07:34 AM
jpalamar's Avatar
62k miles and mine are perfect.
jpalamar is offline
post #4 of 9 (permalink) Old 08-06-2010, 03:56 PM
Have had a 2004 for a couple of weeks and read about this problem. Slight wear through the yellow tag with no indication anyone had treated the problem in the past. Put a 3/4" water system hose around it and put the FRC back on. Probably will need to change out the hose every few years as now FRC leaning on it.
dglanzer is offline
post #5 of 9 (permalink) Old 08-06-2010, 04:26 PM
HP11's Avatar
Quoted: 24 Post(s)
Nah, either replace the hose with a braided steel hose or put a braided sleeve over the stock hose like I did and you won't have to worry about it again.
HP11 is online now
post #6 of 9 (permalink) Old 08-08-2010, 08:44 PM
UdnUdnGTO's Avatar
Ok, fine, 132,000 and no problems....The dealership in Topeka, reamed out the cover though.
UdnUdnGTO is offline
post #7 of 9 (permalink) Old 08-12-2010, 05:06 PM
Remove your FRCs and store them some place where they won't get damaged.
I only have mine on if I'm at a show.
Poncho Dan is offline
post #8 of 9 (permalink) Old 08-13-2010, 03:50 AM
Korsakoff's Avatar
04 31k miles and I have a decent size cut... FRC's stay off until I can do something about it.
Korsakoff is offline
post #9 of 9 (permalink) Old 08-13-2010, 09:59 PM
+1 Mine looks about the same. Not enough of a cut to cause a problem, but enough of one to say "dude wtf? that's not right"
My FRCs are off for a number of reasons:
1. Heat
2. Cutting the fuel line
3. Weight reduction
4. Since when did a 400ft/lb motor need introduction?
gto on fire! awsome burnout ricekiller848 Audio & Video Clips 23 09-19-2009 09:56 PM
Which late model booster and master cylinder??? ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-26-2009 04:54 AM
71 gto trying to fire up after long time in field camarocasanova 1964-1974 Tempest, Lemans & GTO General Discussion 25 11-22-2008 09:46 PM
Personalized fire plates for 2006 GTO Daisey_Moonshine The Lounge 10 05-15-2007 01:20 PM
