EVAP Vent Solenoid Pinout? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-31-2015, 08:04 AM Thread Starter
Hey guys. First post. I'm swapping an LS2 from a 2006 GTO into a BMW. I want to retain EVAP. There are several errors in the Holden pinout information. C2 Pin# 54 is listed as EVAP Canister Vent Solenoid Control. It also shows this on the diagram. This is incorrect. C2 Pin# 54 is Ignition Coil #1.
The question then remains, on which connector and pin is EVAP Canister Vent Solenoid Control? The SSR pinouts show the EVAP Canister Vent Solenoid Control on C1 Pin# 54. It stands to reason it would be the same on the GTO, but I need verification.
Any help is appreciated.
Thanks.
Tipsy
TipsyMcStagger is offline
starter solenoid Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-12-2010 02:19 PM
Reverse Solenoid LS2 MN6 Service, Maintenance and Technical Discussion 3 08-02-2010 11:26 AM
shorting a solenoid. Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-02-2009 05:23 PM
GTO Electric Fan Wires ( pinout ) spestis 2004-2006 GTO General Discussion 2 08-27-2009 08:43 PM
1 -> 4 solenoid locator help Mikey Service, Maintenance and Technical Discussion 8 09-07-2005 08:53 AM
