Fault code - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-07-2010, 03:23 PM Thread Starter
The intimidator's Avatar
Fault code
I would like to know what is a smart alternator fault code is??. How do I fix it? Any help would be helpful Also where is the IAT sensor located?? anyone with pictures?
The intimidator is offline
post #2 of 3 (permalink) Old 03-07-2010, 04:57 PM
HP11's Avatar
Quoted: 24 Post(s)
What's the fault code number? The only time I've ever seen the term "smart alternator fault" was on a Ford. The reason I asked about the fault code number is that most tuners show code P1632 as the fault you mentioned but that's wrong because the 'smart alternator' thing is a Ford thing. If that's the code you're getting, the code number is proper, P1632, but in GM codes it's a theft system-fuel cutoff fault. Unfortunately, I've never experienced it and don't know how to fix it.
HP11 is online now
post #3 of 3 (permalink) Old 03-09-2010, 02:04 AM
87GN06GTO07IRL's Avatar
On 05-06 its part of the maf. Iat relocate with a breakout harness is the way to go so it wont pull as much timing.
87GN06GTO07IRL is offline
Audio Fault.... Aramz06 Service, Maintenance and Technical Discussion 1 07-04-2009 11:04 AM
Air bag FAULT GoatOnMeth Service, Maintenance and Technical Discussion 3 05-13-2009 09:47 PM
ABS fault at 145 mph!!! banshee 2004-2006 GTO General Discussion 8 11-05-2008 04:44 PM
ABS Fault muohio Service, Maintenance and Technical Discussion 5 05-07-2007 11:32 PM
AirBag Fault DJ_YellowGTO Service, Maintenance and Technical Discussion 1 02-02-2005 08:45 AM
