a few clutch questions - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-21-2013, 06:31 PM Thread Starter
06 gto, bought it with 50,000 miles about a month ago. I am just curious about the clutch and what you guys experience with your goats. Im not sure if it has an aftermarket or what. To fully disengage the clutch, i need to be almost all the way to the floor, is this normal? I also notice a shudder and sometimes chatter if i let the clutch out very slowly like in traffic, or if i put it at like 1200rpms while a release. This shudder happens only when the car is good and hot. Also can someone get a reading on how much pressure their pedal takes to push, because im no wimp, but it seems to be stiffer than the huge john deer i drive daily.
Not really any problems when im by myself because i like speed and dont mind being a bit rough, this is usually only when i have a passenger and i am trying to be smooth and more gentle for them.
clutch has zero slip BTW
06Goat88Rc is offline
post #2 of 2 (permalink) Old 06-21-2013, 08:39 PM
Sounds like an aftermarket that needs a good fluid bleed. Try that first. It could also be the slave needed a shim when the clutch was installed and the owner just had a clutch thrown on without measuring.
Clutch bleeding- couple questions NomNom Service, Maintenance and Technical Discussion 6 08-28-2012 04:51 PM
Installed Tick clutch master. Clutch pedal feels different. SplitFire Drive train, suspension, alignment and brakes. 12 01-18-2012 05:15 PM
clutch issues and questions! Johnson_05goat Drive train, suspension, alignment and brakes. 4 10-17-2011 01:52 PM
Some Clutch Issue Questions Falco21 Drive train, suspension, alignment and brakes. 5 09-03-2011 10:23 AM
Twin disc clutch questions ROBSGTO Drive train, suspension, alignment and brakes. 9 06-26-2010 10:39 PM
