First Oil Change Time - Pontiac GTO Forum
post #1 of 11 (permalink) Old 04-01-2007, 02:10 AM Thread Starter
It's time. '04 5.7 LS1. I was thinking Mobil 1 5W30 w/ Mobil 1 filter. Any suggestions?
Have you ever thought that the people you talk to online are perfectly normal....and that YOU are the psychopath?
SnKGoat is offline
post #2 of 11 (permalink) Old 04-01-2007, 02:12 AM
purple royal... or royal purple whatever it is.
sniper.x611 is offline
post #3 of 11 (permalink) Old 04-01-2007, 07:39 AM
SANDU002's Avatar
I have also heard RP works better for manual trans.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 11 (permalink) Old 04-01-2007, 08:07 AM
silversport's Avatar
good choice...the K&N oil filters are rated highly as well...have been using them on my LS-1 Vette for a couple years...I used to use the AC Delco Gold (UPF) but read that while filtering the best, it was more restrictive (DUH!) so I stopped as it raised oil pressure a bit...good luck, I am due for the first oil change on mine as well...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #5 of 11 (permalink) Old 04-01-2007, 09:06 AM
dizzy1
Guest
Posts: n/a
Quoted: Post(s)
oil change
go with ROYAL PURPLE
post #6 of 11 (permalink) Old 04-01-2007, 09:11 AM
dizzy1
Guest
Posts: n/a
Quoted: Post(s)
oil change
your 1st change,,, how many miles are on it.. I did my 1st change at ZERO miles.. day of delivery I told the dealer to change the oil because it comes from the factory with Mobile One,, with synthetic oil.. the car will never break in properly. I did another change at 500 miles, again at 1500, again at 2500 and then I went to Royal Purple at 3500
post #7 of 11 (permalink) Old 04-01-2007, 09:26 AM
1st oil change on an 04?! GARAGE QUEEN!!
PEARL JAM is offline
post #8 of 11 (permalink) Old 04-01-2007, 12:07 PM
dizzy1
Guest
Posts: n/a
Quoted: Post(s)
oil
how many miles are on it.. go with royal purple
post #9 of 11 (permalink) Old 04-01-2007, 12:11 PM
pickinfights's Avatar
I would suggest using the search button. This topic has only been brought up five billion times.
pickinfights is offline
post #10 of 11 (permalink) Old 04-01-2007, 12:38 PM
b_a_betterperson's Avatar
Switching from dino to a synthetic is a good move. Did it on my '04, too. What was really interesting is that my temp gauge used to go to halfway between hot and cold on dino -- then dropped to 3/8 after going to synthethic. That's amazing.
b_a_betterperson is offline
