Fluid Servicing? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-15-2010, 10:52 AM Thread Starter
Fluid Servicing?
Please, no flames...
Im finally getting around to changing out all my fluids on my 05 GTO AT.
How many quarts does the LS2 take? Im thinking 6, just wanna make sure.
Im using Mobil 1 10w-40 synthetic, is that ok?
Also using the Mobil 1 filter.
ALso gonna do the Diff fluid and use Royal Purp Max Gear 75W90, that sound right?
and last but not least, the AT fluid. I have never done this before, is it difficult to do? Is there a DIY art here that I am missing?
I was thinking the Royal Purp AT fluid.
thanks... I appreciate it.
Im new to the V8 world, so tho ive done plenty of oil changes on my own, not much else has been done by me, and now I am learning and want to make sure I get everything right.
symbian is offline
post #2 of 6 (permalink) Old 03-15-2010, 11:07 AM
HP11's Avatar
Quoted: 24 Post(s)
Here's some guidelines. I think 10w-40 is too thick. The factory calls for 5w-30. The author of this article is using 0w-30. Follow the guidelines of this article but use the fluids of your choice as long as they're withing the factory guidelines.
Differential, Manual Transmission & Engine Oil changes
HP11 is online now
post #3 of 6 (permalink) Old 03-15-2010, 11:40 AM
68greengoat's Avatar
Look at your owners manual. All the capacities and types of fluids will be listed.....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 6 (permalink) Old 03-15-2010, 11:42 AM
jpalamar's Avatar
Read your owners manual for fluid specs... AND EXPECT TO BE FLAMED.
I use whatever oil is on sale for my motor(5W30 because thats what the manual says). I've been sticking with the Pureolator filters because they get decent reviews and are reasonable priced. I wouldn't buy any special filters because I haven't seen measurable results.
I am however considering switching to the Mobile one expended life 12,000 mile oil and special filter for convenience though.
I use Royal Purple 75W140 in the diff(it is what the manual says) however the new GM part number for it is 75W90? Needless to say, 53k miles and no issues.
Also, I don't belive the A4 is too hard to do. I would assume it is the same as most cars, drain, drop the trans pan, replace filter, and put the trans pan back on (new gasket usually comes with filter) or use RTV(let dry before putting fluid in)
04 GTO - sold
jpalamar is offline
post #5 of 6 (permalink) Old 03-30-2010, 04:50 AM
87GN06GTO07IRL's Avatar
Don't forget to change your brake fluid. Seems like a lot of people want to go fast and don't care about stopping. Brake fluid breaks down and oxidizes fairly quickly.
87GN06GTO07IRL is offline
post #6 of 6 (permalink) Old 04-04-2010, 09:21 PM
+1 on the brake fluid. That IS the most over looked fluid. And don't go by color. I have seen golden colored fluid fail the test strip test. But if it black then deff. change it ASAP. And don't just remove and refill the master cylinder. Make sure to flush the lines after changing the fluid in the M/C.
If you plan on doing much high speed driving. I would reccomend switching to a hi performance brake fluid like the ATE Super Blue.
awdjdmtalon is offline
Clutch Fluid canadianGTO 2004-2006 GTO General Discussion 5 11-15-2009 01:58 PM
tranny fluid v8newb Service, Maintenance and Technical Discussion 0 02-28-2009 02:52 PM
Brake Fluid GNX231 2004-2006 GTO General Discussion 8 07-19-2007 01:55 AM
what brake fluid do you use roadracer Service, Maintenance and Technical Discussion 1 05-02-2006 03:54 PM
Synchromesh Fluid ModBoss2 Service, Maintenance and Technical Discussion 46 12-24-2005 08:46 AM
