front of car shakes when letting rpms drop down - Pontiac GTO Forum
post #1 of 9 (permalink) Old 03-19-2014, 08:30 PM Thread Starter
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
whenever I get my rpms high usually around 3~4k and i let off of the gas and have the engine run down sometimes the dashboard area starts to shake violently. its not like a stall. When the Rpms get to about 2k it stops and my car is fine. Can it be something to do with the drive shaft like the U-joint? Any help would be awesome!
Gto-noob is offline
post #2 of 9 (permalink) Old 03-20-2014, 10:39 AM
700Rocket's Avatar
rev it up in the driveway sitting still and report back if it does it then.
700Rocket is offline
post #3 of 9 (permalink) Old 03-20-2014, 03:41 PM Thread Starter
no sir. It is while only in gear and in any gear.
Gto-noob is offline
post #4 of 9 (permalink) Old 03-23-2014, 02:13 PM
68OldGoat's Avatar
A bit more information would be helpful!
What year and is your car Auto or Manual? How many miles? Fluid service history would help!
When the car first starts to vibrate, put the car in neutral and see if the vibration stops or continues.
What does the car do when accelerating from 2K through 4K?
68OldGoat is offline
post #5 of 9 (permalink) Old 03-27-2014, 01:28 PM Thread Starter
2006 manual 166,xxx. oil has been changed about every 3k miles. changed tranny fluid probably 4 months ago. vibration does stop when putting into neutral. cars runs perfect while accelerating no sounds,doesnt feel sluggish, and no vibrations. I heard it could do something with the steering rack due to a bad bearing.
Gto-noob is offline
post #6 of 9 (permalink) Old 03-27-2014, 09:11 PM
could be the drive shaft
post #7 of 9 (permalink) Old 03-28-2014, 11:02 AM
68OldGoat's Avatar
Sounds like you need to get in on a rack and start looking for loose parts!
Drive-shaft
Steering Rack
Engine pulley ...bearings
Suspension parts... bushings and etc.
At 166K+ there are bound to be some parts that are worn out and never been changed. Some mechanics use a stethoscope to find subtle worn out parts by listening for vibrations.
post #8 of 9 (permalink) Old 03-31-2014, 01:30 PM Thread Starter
thank you so much !
Gto-noob is offline
post #9 of 9 (permalink) Old 04-09-2014, 02:56 PM
SIXO GTO's Avatar
Defnietly check the gulibos & carrier bearing on the driveshaft for play or rips , lol why those are installed are beyond me , never saw a car or truck for that matter in my 21 years as a tech have that type of thing on them except on a gto ? even the type of rubber dampeners on the foreign cars are better designed... also have you checked your strut bushings?
SIXO GTO is offline
Front right wheel has the shakes rebel101150 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 12-05-2013 08:13 PM
3/8" drop front, 0 drop rear springs Red2005Goat 2004-2006 GTO General Discussion 0 07-13-2013 06:22 PM
Engine stops giving gas. rpms drop. hockey499s Service, Maintenance and Technical Discussion 3 05-18-2012 11:19 PM
car hesitating at low rpms gspeed Service, Maintenance and Technical Discussion 1 04-06-2011 08:06 PM
