Fuel filter? - Pontiac GTO Forum
post #1 of 22 (permalink) Old 09-06-2007, 09:56 PM Thread Starter
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
Fuel filter?
the goat has past its 30,000 mile check up and i need to know where is the fuel filter located. is it on the frame or in the tank. not talking about fuel pump. thx for you help
EEZ GOAT is offline
post #2 of 22 (permalink) Old 09-06-2007, 10:09 PM Thread Starter
Premium Member
EEZ GOAT's Avatar
so at 30,000 i dont need a new filter?
the sheet says i need fuel/air inductuon service
throttle body service
coolant additive (wtf is that)
totate tires and adjust pressure
complete brake inspection (dont midas do that for free)
rear differential service
oil an dfilter change (non syn)
Install BG on the road kit (got me on that one guys)
top off all fluids
lub chassis components
visual car inspec
inspect undercarriage for damage or leaks
trans flush
multi point inspection and test drive all for as little as..........
600+ dollars
EEZ GOAT is offline
post #3 of 22 (permalink) Old 09-07-2007, 05:18 AM
Our GTO's have no servicable fuel filter. The fuel filtration device is a fixed part of the fuel pump. Many newer cars and trucks are going this route. Personally, I'd ather have one I can change every so often.
PEARL JAM is offline
post #4 of 22 (permalink) Old 09-07-2007, 06:44 AM
GM4life's Avatar
top off all fluids
visual car inspec
trans flush
600+ dollars
If you have the time you can do most of that stuff yourself. That the stuff I do in my garage every six months. Now if you have auto tranny than yes I would take it in to have it flushed if needed, changing fluid is no problem. Where did you get that sheet from because I looked up all the recommended stuff to check on the GTO and some of that is not listed. Do you have the owners manual I would go by that, thats what I recommend.
The dealer wanted to do some mileage required service on my car after seeing the price of $400+ I told them no thanks. That is the stuff that I can do and I know it's done, I keep records and recepts of everything done to that car.
Having the lack of a fuel filter I put fuel system cleaner in my tank every once in awhile.
GM4life is offline
post #5 of 22 (permalink) Old 09-07-2007, 08:35 AM
top off all fluids
visual car inspec
trans flush
600+ dollars
When I get my car's oil changed at the dealership they do most of the above during that service. I bring my own oil and filter so for 14.99 all the fluids are topped, chassis lubed, visual on brakes and everything else is done. It is all documented on the paper I get. For 600 clams they are charging a lot for mostly looking
I have no idea what a BG road kit is
Personally I would have nothing major done until it has to be done i.e. changing the rear diff fluid, throttle body, air induction service etc. I have seen some good quality air cleaners for 9.99 or so.
I won't get all that done until I have to.
post #6 of 22 (permalink) Old 09-07-2007, 10:41 AM Thread Starter
Premium Member
EEZ GOAT's Avatar
me and my buddy are going to do the oil/filter change, diff chang (to Royal Puple) btw what kind should i get for the diff? will let the dealer do my trans change and and TB work
EEZ GOAT is offline
post #7 of 22 (permalink) Old 09-07-2007, 10:55 AM
Not sure what the Royal Blue gear oil is for that but any parts house that deals with Royal Purple products should be able to direct you to the correct oil. Maybe call the dealer and ask what viscosity they use and find the same in Royal Purple? When my diff oil was changed out by the dealer they put in a modifier to help with any kind of noise coming from back there. It's supposed to help keep the rear quiet. You may want to install the same when you change out yours. Just my 2 cents.
post #8 of 22 (permalink) Old 09-07-2007, 11:19 AM Thread Starter
Premium Member
EEZ GOAT's Avatar
should i use RP in the trans for better performance?
EEZ GOAT is offline
post #9 of 22 (permalink) Old 09-07-2007, 11:52 AM
Many swear buy it..It's highly rated.
post #10 of 22 (permalink) Old 09-07-2007, 12:54 PM Thread Starter
Premium Member
EEZ GOAT's Avatar
the way i run the gears i guess i better use it than. will it void gm warn?
EEZ GOAT is offline
