Gauge TSB? - Pontiac GTO Forum
post #1 of 15 (permalink) Old 02-13-2007, 08:35 PM Thread Starter
pickinfights's Avatar
Gauge TSB?
Does the eratic gauge thing realy have a TSB on it??
My goat was in the garage from 9-close today, and they still have not figured it out. If it truly is a TSB I should get it printed out and bring it to court next speeding ticket.
pickinfights is offline
post #2 of 15 (permalink) Old 02-14-2007, 09:17 AM
coolhandgoat's Avatar
From that other site:
Speedometer Erratic Movement, Fuel Gauge Does Not Go to Full After Filling, Engine Coolant Temperature Gauge Reads Hot and Coolant Temperature Light Illuminates (Reprogram IPC) #05-08-49-003 - (Jan 20, 2005)
2004 Pontiac GTO
Built Prior to VIN Breakpoint 4L296011
Condition
Some customers may comment on one or more of the following conditions:
• Speedometer jumps erratically. Gauge may go up to 200 MPH or not return to zero.
• Fuel gauge does not move off empty when tank is full.
• Engine coolant temperature gauge reads hot and coolant temperature light illuminates.
These conditions may be intermittent.
Correction
Technicians are to reprogram the IPC with an updated software calibration. This new service calibration was released with TIS satellite data update version 1.0 available January 10, 2005. As always, make sure your Tech 2® is updated with the latest software version.
Important: Vehicles built after the VIN breakpoint must have the IPC replaced to correct these conditions
coolhandgoat is offline
post #3 of 15 (permalink) Old 02-14-2007, 05:59 PM Thread Starter
Day two is over in the shop and they still have not fixed my car.
What the f***.
post #4 of 15 (permalink) Old 02-14-2007, 08:21 PM
Not according to the dealers I took mine to no TSB and said it wasnt an issue.
Just like all the other problems
Taxman is offline
post #5 of 15 (permalink) Old 02-14-2007, 09:20 PM
my 04 did that
hi, my 04 speeedo would go to top spped in both digital and dial at around 20mph at infrequent times. dealer replaced dash per other post, no problems with that since( darn thing still eats batteries)
hdisandman is offline
post #6 of 15 (permalink) Old 02-15-2007, 09:49 AM
I guess I forgot to mention in my earlier post that I had the problem with the speedo going to 200 and back, I took it into the dealer and they fixed it as per this TSB.
As for your dealer not finding the TSB, try having them use a different search modifier-- my service rep swore up and down for 15 minutes there was no such thing, and then this crusty old tech walked up, said "watch this", and like magic it appeared on his first try. If I remember right the service puke was searching for gauges and the tech searched for speedometer (but I could be totally wrong).
post #7 of 15 (permalink) Old 02-15-2007, 12:42 PM
I had all three symtoms and they replaced the Instrument Cluster. No problems since. I think my speedometer reads fast, any ideas?
smokin455 is offline
post #8 of 15 (permalink) Old 02-15-2007, 12:49 PM
b_a_betterperson's Avatar
Yes. The thing is most Pontiac dealers aren't familiar with these cars and have no clue as to how to fix it. If push comes to shove, have your dealer call Mike White at Lehmers Pontiac in Concord, CA as he's one of very few people who know what they're doing with these cars.
b_a_betterperson is offline
post #9 of 15 (permalink) Old 02-15-2007, 04:14 PM Thread Starter
Do you have his number? I just got my car back (after three days). But i'm sure i'd need it in the future.
post #10 of 15 (permalink) Old 02-15-2007, 07:52 PM Thread Starter
To top it all off, they left me with NO gas in it.
