Got an 06 today, its stalling - Pontiac GTO Forum
post #1 of 25 (permalink) Old 06-02-2013, 02:17 AM Thread Starter
Got an 06 gto, now coolant leaK, + mysterious starting
Just bought an 06 gto today, 49000 miles, 6spd, all stock except a Knn filter. Never owned a manual, or a fast car, but I have been a fan of the gto for a long time.
Ran good today except for when I got home, started stalling and studdering at low speed. I revved it up a bit and took off again and that is when my traction control went off. I could not turn it back on again until the car was shut off and back on, then everything worked normal. Troubleshooting this problem led me to this site, and now i have an idea that it might be the MAF sensor malfunctioning,, seeing as i have a knn also. Kind of a scary thing to happy to my car on the first day i own it.
Anyways, Im new here, thanks for any help in advance, im sure i will be here often now
06Goat88Rc is offline
post #2 of 25 (permalink) Old 06-02-2013, 03:49 PM
Over oiled filters are a fairly common problem and affect fueling. Buy a MAF cleaner and CAREFULLY spray the MAF sensor and let it dry. Also double check the MAF connector
post #3 of 25 (permalink) Old 06-02-2013, 05:48 PM Thread Starter
Yep
I had autozone pull the codes today and sure enough the maf popped up as being intermittent. Since the car has a warranty that covers this, i think i will just get a free replacement and start new. I cant seem to figure out how to disconnect the wire anyways, im used to working on my old school truck, not all this new fangled computer stuff.. Im glad i found this site though, i have a similar site for my ramcharger and it has been so usefull
post #4 of 25 (permalink) Old 06-02-2013, 08:07 PM
The wires plug straight into the MAF. A new one should fix it but hopefully it isn't an over oiled filter issue that could contaminate the new MAF. FWIW these newfangled computer" cars are easier to work on than all but the oldest school cars.
post #5 of 25 (permalink) Old 06-02-2013, 10:00 PM
Seen this many times. Replacing the MAF sensor could lead to the same codes.
I would clean the K&N air filter again being careful not to over oil it, clean the MAF sensor with the right cleaner, re-set the codes and go from there.
post #6 of 25 (permalink) Old 06-02-2013, 10:18 PM Thread Starter
I see the wire going into the MAF, but I dont want to break it, it doesnt seem to want to come out, it doesnt just unplug, there is usually a safety of some sort and i cant figure it out lol. The MAF is a 2 inch long section of the intake tube right? on my knn it butts right up next to the box so oil seems like a reasonable cause, the filter looks pretty dry though. I drove about 50 miles today on and off like 8 times and never had a problem. I think i will do some exploratory surgery tomorrow if i can get the damn wire to disconnect. i wanted to clean the filter and tube up anyhow because the dealership left it looking kind of crappy.
Oh and also, what could i clean the MAF with, without having to go to autozone again.
post #7 of 25 (permalink) Old 06-03-2013, 07:36 AM
Only use MAF sensor cleaner, others can screw it up and damage it.
If you can post a pic of the plug we can tell you how to get it off.
post #8 of 25 (permalink) Old 06-03-2013, 09:10 AM
LS2 has a 5 wire MAF plug that's linear and it is right at the MAF. There's just little clip like things you bend out a bit with a small screwdriver. If you clean a filter and re-oil I always suggest laying it on an old bath towel out in the sun for an afternoon to wick out any excess.
post #9 of 25 (permalink) Old 06-03-2013, 12:52 PM Thread Starter
I bought some maf cleaner this morning and i think the screwdriver under the catch of the wire will work just fine. Thank you guys for the help, ill let you know if this fixes my problem when i can get around to cleaning it later today
post #10 of 25 (permalink) Old 06-03-2013, 01:16 PM
If you take it back to the dealer they may not stand behind the MAF if the K&N air filter is on there. If the PO gave you the original air filter be sure to put that back on before going.
69 LeMans Stalling 69LemansCV 1964-1974 Tempest, Lemans & GTO General Discussion 18 06-12-2013 06:20 PM
my lemans keeps stalling out poncho power 1964-1974 Tempest, Lemans & GTO General Discussion 4 04-01-2013 12:21 PM
Stalling Issues Shorty29 Service, Maintenance and Technical Discussion 3 03-20-2010 10:06 AM
New mods and Stalling Dan81 Engine Discussions 7 10-22-2009 10:08 AM
Car is stalling gcone 2004-2006 GTO General Discussion 10 10-19-2004 10:52 PM
