Got a leak, need some advice. - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-18-2011, 12:03 AM Thread Starter
Wassup everyone. I've got air leaking out of the drivers side cylinder head. I hope I explained that right...it's coming out in the rear all the way in the back. I retightened the bolts cuz I found a few not too tight hoping that would do the trick but nope. Car runs without any problems but you can hear it "farting" all the time. My question is is it as simple as just replacing the cylinder head gasket? I'm ok with little reparis but havent done anything thing like this before
and def dont wanna mess anything up and also if Im gonna change one side guess I should change the passenger side as well to avoid future problems? Thanks a ton in advance guys. Be safe. peace. RC.
Red And Angry is offline
post #2 of 5 (permalink) Old 03-18-2011, 02:11 AM
87GN06GTO07IRL's Avatar
Post a pic pointing at the exact area.
87GN06GTO07IRL is offline
post #3 of 5 (permalink) Old 03-19-2011, 12:03 AM Thread Starter
Correction. My bad. Found the leak. Should have done a more thorough search. It's coming from the header. Got a burnt finger for confirmation in the process . Guess I'll try some gasket sealant if not just change out the old ones for new ones, guess the same question applies, should I change the passenger side as well to avoid future problems? Sorry for the mishap. Peace. RC.
post #4 of 5 (permalink) Old 03-21-2011, 12:01 PM
jpalamar's Avatar
Don't waste your time with gasket sealant. You need to replace the gaskets. I would also looking into switching to studs rather then header bolts. Maybe even consider doing a long tube install :-)
jpalamar is offline
post #5 of 5 (permalink) Old 03-31-2011, 11:39 PM
YellO5LS2's Avatar
If money isn't an issue or the leak isn't annoying you and you can wait get the SLP set up with new headers and high flow cats on their mid pipes. Awesome sound and awesome power!
YellO5LS2 is offline
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
HELP! Fuel leak Flyboy 1964-1974 Tempest, Lemans & GTO General Discussion 6 12-11-2009 03:08 PM
Water Leak in '06 Ladybug Interior Discussions 3 12-12-2008 02:17 PM
comparison the "cant break 8s" b4 advice and after the advice DK2F Service, Maintenance and Technical Discussion 0 02-11-2006 03:09 AM
Transmission Leak Jerry Libes 2004-2006 GTO General Discussion 0 05-18-2005 08:41 AM
