GTO HAL is driving me crazy - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-29-2006, 05:11 PM Thread Starter
Russ2005's Avatar
My GTO computer seems to be going wacko lately...
1) June, the stereo cut itself off magically by itself while driving one day. I have read other reports on this forum of that happening. It has only happened once.
2) Late July - I started the engine and got ENGINE icon and the "degregated performance" message. I shut off the engine and got the same error reported again. I tried a third time and the error cleared itself. I have not seen that problem again
3) Mid-August - Started the engine and got "degregated performance" message again (no icons this time). I got to the dealer to read the code and it said "accelerator petal stuck". The reset the code, restarted the engine and I have not seen that come back again.
4) yesterday I sarted the engine and got ABS Failure - Trac Off error. I turned off and back on and it went away. Today, I was driving and out of nowhere the ABS Failure - Trac Off error came back. I turned off and back on and it is cleared again.
..........is the onboard computer driving anyone else nutz?
As long as these errors are resetting themselves should I be concerned? The one that sucked was the accelerator error did not reset itself and I had to drive about 5 miles in what seemed like a 4 banger.
Russ2005 is offline
post #2 of 4 (permalink) Old 08-29-2006, 05:42 PM
Napoleon_Tanerite's Avatar
you should have it fixed while it's still under warranty. just because the symptoms go away doesnt mean the problem is gone
please disregard the previous message
Napoleon_Tanerite is offline
post #3 of 4 (permalink) Old 08-29-2006, 05:46 PM
The_Goat's Avatar
"I'm sorry Dave..... I can't do that"....
I had a problem similar to yours with the accelerator position sensor. They replaced it and haven't had a problem since.
The_Goat is offline
post #4 of 4 (permalink) Old 08-29-2006, 07:08 PM
Man, sounds like gremlins, lucky me no errors. I feel for you. Please post more info as it pops up. Not much info on these cars.
aintmisbehavinn is offline
