gto key wont turn - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-23-2016, 01:11 PM Thread Starter
gto key wont turn
2005 gto key physically won't turn , I ordered the new revised cylinder , but in order to remove the old cylinder you need to turn the key to on position ,then push the the little button with the Allen wrench ,what do I do ,my steering wheel is also locked
sskillaz is offline
post #2 of 6 (permalink) Old 06-23-2016, 02:18 PM
GTO44's Avatar
Quoted: 44 Post(s)
Sorry man not sure what you would do. If you don't already have step by step directions here's a great guide.
Ignition Cylinder removal and disassembly
Doesn't address how to proceed if you can't turn the key in the ignition tho...
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 6 (permalink) Old 06-23-2016, 02:28 PM Thread Starter
yea I read so many guides and watched ask the videos on YouTube no one really goes on about what to do if your key is seriously stuck I tried graphite lube ,I'm gonna try using compressed air now ,
sskillaz is offline
post #4 of 6 (permalink) Old 06-23-2016, 03:18 PM
GTO44's Avatar
Quoted: 44 Post(s)
I'm sure you've already tried this... But....
Try turning the wheel left to right super aggressively as you try to turn the key. Maybe it's stuck against the steering wheel lock.
I've gotta do that to get the key to turn in my company car.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
post #5 of 6 (permalink) Old 09-14-2019, 11:58 AM
hi, im having the same problem key wont turn at all. how the.. did you ever fix your problem!!??
GTO_Cali_k is offline
post #6 of 6 (permalink) Old 09-15-2019, 04:29 PM
^^UPDATE: If your key is just completely stuck and won't turn for you to unlock the cylinder with the pin/Allen key... Just keep playing with the key and steering wheel (if locked) at the same time trying to get it to turn to "on position" where you can then proceed with the Ignition Cylinder Replacement process.
careful not to force the shit out of it so you don't break anything, gentle force twisting/turning will do.
Interior lights wont turn off... bendonnelly 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 16 05-15-2016 08:44 PM
turn signals wont work GTO2010 2004-2006 GTO General Discussion 2 03-02-2011 04:41 PM
Wipers wont turn off???????? 06 6.0 ndria12 Service, Maintenance and Technical Discussion 2 02-18-2011 07:40 AM
key wont turn...plz help. =[ GTO19020 Service, Maintenance and Technical Discussion 4 10-19-2009 04:10 PM
67 GTO wont turn when hot gsmed 1964-1974 Tempest, Lemans & GTO General Discussion 7 08-20-2005 09:04 PM
