GTO Overheating--Steps Taken - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-19-2011, 08:19 AM Thread Starter
In mid November my 2005 GTO (6spd w/ 72k miles) began getting large temperature spikes, pegging the gauge and giving the Engine Temp warning chimes.
I had the thermostat replaced at a local Firestone (normally I'd do this type of things myself but I'm not really in a position to be able to do work on my own car right now). The car behaved perfectly for about 35 days--no temperature spikes. Then they suddenly started again worse than ever. I would go 2-3 miles and get a spike. I immediately took it back to Firestone and they replaced the thermostat again under warranty. unfortunately no-dice, the problem persisted.
Next I replaced the temperature sensor. This I did myself and the car again behaved for about 3 weeks. This morning the temperature again began spiking. I'm at my wits end with this thing--anyone have advice or had a similar problem?
davidbutzin is offline
post #2 of 4 (permalink) Old 01-19-2011, 02:12 PM
jpalamar's Avatar
Radiator cap since your an LS2 would be a possibility as well as a cheap replacement.
I'm assuming you don't have any leaks and your coolent level is where it should be.
jpalamar is offline
post #3 of 4 (permalink) Old 01-21-2011, 01:59 PM
Leahburk714's Avatar
I had the thermostat replaced at a local Firestone. I would go 2-3 miles and get a spike. I immediately took it back to Firestone and they replaced the thermostat again under warranty. unfortunately no-dice, the problem persisted.
Does it do this when u first start up and or while parked will it shut off when u go down the rd, i just posted on another link my problems with mine as well.
06 PBM GTO M6, Diablo Tune, Kooks L/T Catless, MGW-P, T/B, Driveshaft Shop Axles, CAI
Leahburk714 is offline
post #4 of 4 (permalink) Old 01-21-2011, 03:29 PM
oryfoxer7410's Avatar
When you checked your coolant, was it boiling? I am having phantom temp spikes also. It happened to be a few days ago and then went away out of nowhere. The only thing is, when I checked under my hood, my coolant was boiling.
BTW, I have a thread about my issue already opened, if anyone has a suggestion to my issue, please reply to it.
PROUD GTO 6.0 OWNER
Houston, Texas... Always looking for another GTO fan in my area. PM me if you live in Houston.
oryfoxer7410 is offline
o6 gto overheating takethegoat Service, Maintenance and Technical Discussion 15 02-09-2012 09:14 AM
Gto overheating Weisberg16 Service, Maintenance and Technical Discussion 4 02-13-2011 12:29 PM
Gto Overheating williamp302 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 30 02-04-2011 04:21 PM
Rick Wagoner Steps Down GTO JUDGE In the News 5 04-05-2009 06:14 AM
Watch where your goat steps EEZ GOAT The Lounge 11 01-01-2009 11:12 PM
