GTO Rack and Pinion Leak (On connection) PLEASE Help - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-14-2013, 02:22 PM Thread Starter
Ok on the rack and pinion, there is the gear box part, where there are 4 tubes connected. On the side closest to the engine, there is a bigger one and a smaller one, the bottom one leaks like crazy. I cant quite tell what the problem is, i want to replace the pipe going to it, but i cant find it.
I have the spot pointed out in the picture, it leaks from the side of the bolt, any ideas? Thre is a small possibility it could be a seal, but im not sure.
PLEASE Help !
GaryReen1 is offline
post #2 of 2 (permalink) Old 05-14-2013, 04:04 PM
If that line fitting is tight, I would remove it and check the o-ring that goes over end of the tube. It might be torn or missing. If it's not on the end of the tube, check inside the rack.
Better Ratio Rack and Pinion rob_szma1212 Drive train, suspension, alignment and brakes. 1 08-23-2011 05:32 PM
Rack N Pinion KarLvr 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-14-2010 07:11 PM
Rack and Pinion Parts mercdoc Drive train, suspension, alignment and brakes. 4 10-31-2010 11:28 AM
Rack and pinion in a 67? Need help bagged67 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-22-2010 04:38 AM
'04 GTO Rack and Pinion Leak=Fire Hazard rxdoc Service, Maintenance and Technical Discussion 9 03-09-2005 12:58 PM
