GTO Squeak - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-24-2013, 12:59 PM Thread Starter
GTO Squeak
I have had my 06 GTO for a few years and have frequented these forums for tips and tricks to make repairs to my goat. However, recently I have encountered a problem that I can not crack.
My GTO has always been a bit squeaky, early mornings or in wet climates. Recently though it has gotten worse. I read up on the forum and replaced my belts (both serpentine and A/C Compressor) to no avail. I then went for the tensioners, however after taking the A/C tensioner off I opted to crank her up just to verify that with both belts off I could not hear the noise. It just happened that the noise was not gone with both the belts and the lower tensioner off. I am stumped, the sound appears to be coming from the engine itself.
This is a link to a video I took on youtube with the belts off:
https://www.youtube.com/watch?v=uMWaY-umgU8
If anyone knows what this noise is and what I can do to fix it I would greatly appreciate it.
-Joaquin
Joaquin is offline
post #2 of 5 (permalink) Old 08-24-2013, 02:47 PM
Steamwalker's Avatar
Just out of curiousity, can you reproduce the sound when the engine is not running? Try moving the engine by hand to test for squeaky motor mounts.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 5 (permalink) Old 08-24-2013, 04:10 PM
700Rocket's Avatar
Auto or Stick? Miles on the car?
700Rocket is offline
post #4 of 5 (permalink) Old 08-24-2013, 04:57 PM Thread Starter
Stick and 60k Miles
Joaquin is offline
post #5 of 5 (permalink) Old 04-19-2015, 07:02 PM
Nothing? Mine's been doing this for some time now, similar description to yours, early morning etc. I've changed water pump, both tensioners, both belts, idlers, etc. Just busted her out for the first time this year and it sounds horrible. Nothing takes the coolness out of the exhaust like that. I haven't started it without belts to see if it makes that noise.
Been reading around and see a lot of instances pointing to a bad lifter. How big of a job is correcting that?
Space is offline
rear wheel squeak irishdude Drive train, suspension, alignment and brakes. 1 06-23-2011 10:42 PM
Brake Squeak The_Goat Drive train, suspension, alignment and brakes. 12 10-13-2009 11:56 PM
Suspicious Squeak 1bad05goat 2004-2006 GTO General Discussion 5 11-11-2008 08:59 AM
Squeak at front of engine JerseyGoat Service, Maintenance and Technical Discussion 3 01-02-2008 10:12 PM
New GTO with Squeak Up Front - Tires Rubbing? codebluemd 2004-2006 GTO General Discussion 2 12-31-2004 05:26 PM
