GTO Stalls? Why? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-29-2007, 02:37 PM Thread Starter
GTO Stalls? Why?
My 06 GTO has a weird stalling issue.
When I restart the car after turning it off for a few minutes (example: run to the store, shut car, off, come back out a few minutes later) the car starts for about 2 seconds then stalls and shuts off.
After the stall, it will start up and run normally.
Seems to happen "every-so-often", not every time.
Anyone have this issue?
XV Scott is offline
post #2 of 8 (permalink) Old 03-29-2007, 04:38 PM
I Used To Have Have That Problem. The Dealer Said They Reprgramed The Pcm. That Stop It. But Now I Cant Burn Rubber
NEXSTAR7 is offline
post #3 of 8 (permalink) Old 03-29-2007, 08:41 PM
What do you mean that you can't burn rubber after the reprogram?
TR GTO is offline
post #4 of 8 (permalink) Old 03-29-2007, 08:49 PM
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
mine did the same thing but i has not in a while. winter cold maybe. they must have locked your tc to on for ever
EEZ GOAT is offline
post #5 of 8 (permalink) Old 03-29-2007, 11:12 PM
b_a_betterperson's Avatar
Just a hunch, but try this: When restarting your car, turn the key to the "on" position. You should hear the fuel pump start running. It runs for a couple of seconds, then shuts off when the line's fully pressurized. See if that changes anything. It's obviously not the equivalent of heading to the dealership for a checkup -- but I do this in mine and never have an issue.
b_a_betterperson is offline
post #6 of 8 (permalink) Old 03-30-2007, 06:09 PM
my bad, i went there for the idle fluctuation i think they did nothing with the program. and i still cant burn rubber by power braking. yes the trac lock is off
NEXSTAR7 is offline
post #7 of 8 (permalink) Old 03-31-2007, 12:03 AM
Mine only does that from a cold start. Sometimes I wonder if its from all the oil 'blow by' (per se) via the pcv system. I had to drill the throttle plate to solve an idle searching issue...........I was amazed at the oil residue inside the intake manifold. Next project: catch can
'06 Torrid Red M6
Cam
Headers
C.A.I.
Shifter
JHP Pod
Pulley
Pedders stuff
Shizon tuned
Route 66 is offline
post #8 of 8 (permalink) Old 03-31-2007, 09:01 PM
you drilled a hole threw the throtle plate? doesant the pcm control the idle or the i.a.c. how did you drill it? and where? my searches on occasions even while hot.
NEXSTAR7 is offline
