header troubles - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-18-2015, 07:56 PM Thread Starter
header troubles
Just installed eldabroc shorty headers and now car runs rough maf code came up, replaced it still persist replaced plugs and wires still persist any clues?? Also idk if in relation but check oil keeps popping up and going away but oil is just fine btw it's a 2004 gto upgrade are kn air filter and slp cat back exhaust
logan4720 is offline
post #2 of 3 (permalink) Old 03-19-2015, 05:08 PM
car runs rough
you need to have a tune done for it all to work.
papousr58 is offline
post #3 of 3 (permalink) Old 03-19-2015, 05:21 PM
Those headers shouldn't make a MAF code come up. Fueling may be a little off but it should not affect idle at all unless you have a pretty big exhaust leak. The K&N may have oiled up the MAF sensor. I would start by making sure you don't have any leaks in the intake path and to carefully spray the MAF sensor with a cleaner made for that.
You'd be best to have a mechanical gauge check of your oil pressure. Just because it has the correct level of oil doesn't mean it is being pumped to minimum pressure. It could also be the oil sending unit is going bad and the mechanical gauge check will verify if it is.
Coolant Troubles need quick help Cole S Service, Maintenance and Technical Discussion 5 06-07-2013 10:11 AM
Hot start troubles Flyboy 1964-1974 Tempest, Lemans & GTO General Discussion 4 06-17-2012 09:44 PM
Brake troubles on a '67...again and again! daveh70 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 11-09-2009 04:56 PM
Radiator Troubles Tyrrel_goat 2004-2006 GTO General Discussion 8 05-09-2008 11:47 AM
70 GTO starter troubles 70GTOConv 1964-1974 Tempest, Lemans & GTO General Discussion 4 03-05-2005 11:43 PM
