help!!! - Pontiac GTO Forum
post #1 of 9 (permalink) Old 03-26-2010, 09:08 PM Thread Starter
Bluegoat05's Avatar
help!!!
hey i have and 05 gto and sometimes when i start my car it will rev to 1500 and then just die. it doesnt happen that often but its got me wonderin whats up with it. my key fob batt has been dying could that be it?
Bluegoat05 is offline
post #2 of 9 (permalink) Old 03-31-2010, 03:13 AM
87GN06GTO07IRL's Avatar
Iac motor might be getting sticky and need cleaned maybe.
87GN06GTO07IRL is offline
post #3 of 9 (permalink) Old 04-09-2010, 04:33 PM
jpalamar's Avatar
Not your key. If your key had issues it wouldn't work at all.
04 GTO - sold
jpalamar is offline
post #4 of 9 (permalink) Old 04-09-2010, 08:21 PM
RJ_05GTO's Avatar
I thought the computer controlled the thottle body blade for idle.
The fuel pump might be getting ready to die. I had the same thing happen in my cavalier. Sometimes i would go to start it and it would start and then die. And it would start and run the second or third time i would try it. It did this a handfull of times before i realized it was the fuel pump. What i did was turned the key on and made sure i heard the fuel pump prime before i started the car and sure enough one time i turned the key on and heard nothing and the car started for like 1 second and died. So listen for the fuel pump to prime before you start it so maybe you could rule it out if it primes and still dies.
05 GTO A4- Svede otrcai, Fast 102, Livernois stg 2 ported heads, Texas Speed 224R cam, Pacesetter LT's, Edge 3000 stall, Kooks afterburners, Pedders 0 drp rear springs and shocks, MT et streets, 418rwhp/391rwtq, [email protected]
RJ_05GTO is offline
post #5 of 9 (permalink) Old 04-10-2010, 09:04 AM
Is it a totally stock car? I'm assuming it is as you have nothing listed for mods.
post #6 of 9 (permalink) Old 04-10-2010, 11:15 PM
Lautinjr's Avatar
I second this completly it's a common problem.
Lautinjr is offline
post #7 of 9 (permalink) Old 04-11-2010, 09:36 AM
Take It To The Dealership......................only Way To Really Find Out.............
john g is offline
post #8 of 9 (permalink) Old 04-11-2010, 02:46 PM
GM4life's Avatar
Originally Posted by RJ_05GTO View Post
I thought the computer controlled the thottle body blade for idle..
Yeup.
GM4life is offline
post #9 of 9 (permalink) Old 04-11-2010, 09:20 PM Thread Starter
Bluegoat05's Avatar
ya that fuel pump definatly makes sense. ill will be sure to listen for it thanks a bunch. and no it is not completely stock i have a aem ca cat back straight pipe jba shorty headers diablo slp tune and jba spark wires.
