Help i have a question please help - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-04-2004, 08:35 PM Thread Starter
HI,
my name is jose and im new to this forum, now i have a question, i know alot about cars but when people start talking about a stroker, and bores i get confused. What is a stroker, and what are bores?
joser69 is offline
post #2 of 5 (permalink) Old 12-04-2004, 09:00 PM
Welcome,
First, the stroke is the distance the piston will travel from the top of the cylinder to the bottom of the cylinder. A "stroker" is when that distance has been modified with a pushrod of a different length and/or a different size crank shaft.
The bore is the size of the cylinder opening, by increasing the bore will allow more volume.
When you bore and stroke an engine you increase the engines cubic inch displacement. In order to see the best results a larger cam is needed to allow for a better flow of the intake and exhaust.
05GTO is offline
post #3 of 5 (permalink) Old 12-04-2004, 09:17 PM Thread Starter
OK I GET IT
joser69 is offline
post #4 of 5 (permalink) Old 12-04-2004, 09:18 PM Thread Starter
if i do that to my '67 GTO with matching numbers engine will it decrease the price?
joser69 is offline
post #5 of 5 (permalink) Old 12-04-2004, 09:25 PM
Boring and stroking an engine should not effect the price. Here is a link regarding a stroker engine.
05GTO is offline
