Help with a squeek? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 09-30-2008, 09:51 AM Thread Starter
Help with a squeek?
First I would like to say Hi to everyone I just picked up a red 2006 6 speed GTO last night. I was driving a GTP for the past year and decided it was time to step up. Ok, now on to my question. I started hearing a squeek, squeek, squeek when driving but mainly just when in gear. I can be going down the road and put it in neutral and coast and it will stop, but once I put back in gear it will start squeeking again. Any idea what it could be? any help would be appreciated.
Nick
GimpsGTP is offline
post #2 of 8 (permalink) Old 09-30-2008, 10:17 AM
GM4life's Avatar
You might have to take a look under the car. Your driveshaft could be rubbing something. Or your exhaust came loose somewere.
Welcome to the forum and congrats on the new ride.
GM4life is offline
post #3 of 8 (permalink) Old 09-30-2008, 10:33 AM
A speed related squeak(sound gets faster as the speed of the car increases) under acceleration (either forward or backwards) could be a U-joint going bad.
post #4 of 8 (permalink) Old 09-30-2008, 10:46 AM
GM4life's Avatar
Thats true, I just read his quote again and it stops when he is coasting and out of gear. The driveshaft is still spinning without a load from the engine. Could be something in the bellhousing, clutch, throw out bearing; but these are small chances. I would take it to the dealer to see whats up.
GM4life is offline
post #5 of 8 (permalink) Old 09-30-2008, 10:50 AM
alsgto04's Avatar
Welcome to the forum.
Ill take it in to dealer you should still have warranty. Good luck.
alsgto04 is offline
post #6 of 8 (permalink) Old 09-30-2008, 02:11 PM Thread Starter
Alright I started it up this morning and it squeeks during idle as well. So im thinking it just may be a belt since the car sat on the lot for like two months.
Nick
GimpsGTP is offline
post #7 of 8 (permalink) Old 09-30-2008, 05:51 PM
Belt tensioner. Maybe.
post #8 of 8 (permalink) Old 10-03-2008, 10:37 PM
coming from the front or back of the engine? the pinion bearings could be the culprit but seeing as how the car is this new i kinda doubt it, but if it is from the back try the sway bar end links, those tend to squeek alot.
gurkgurkgurk is offline
