Hood liner removal - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-17-2010, 06:21 AM Thread Starter
LOWET's Avatar
Hood liner removal
Is it safe to remove the hood liner on our cars without having the fear of distroying the paint on the outside of the hood. Because of the position of my air in take tube for my Procharger I notice where it has rubbed off a section of the liner and it looks like ****. I thought about just cutting out that small section of liner and replace it with a section of heat reflective material or a piece of NON OEM hood liner material. I would rather just rempove the entire liner. What do you think. OK and Safe to do without damaging the paint on the outer hood surface. YES!!!! NO !!!!!
DIZZY
LOWET is offline
post #2 of 7 (permalink) Old 07-17-2010, 08:47 AM
I've herd of plenty of people doing it with no ill effects.
post #3 of 7 (permalink) Old 07-17-2010, 07:02 PM
GM4life's Avatar
Someone had a started a thread on this not too long ago.
GM4life is offline
post #4 of 7 (permalink) Old 07-18-2010, 11:04 AM
The hood liner comes out easy, if you remove the plastic tabs with the claw side of a hammer. A plain old kitchen fork will work too... I used it in my trunk to get at the amp.
Poncho Dan is offline
post #5 of 7 (permalink) Old 07-18-2010, 04:51 PM
PDQ GTO's Avatar
Rip that crap out and polish-up the underside of the hood, you'll dig it for sure. Mine has been out for about 2 years with zero issues of any kind...
PDQ GTO is offline
post #6 of 7 (permalink) Old 07-24-2010, 05:54 AM Thread Starter
LOWET's Avatar
Thanks everyone. sorry it took so long for me to reply. Was back in the hospital again. 5th time in less then two years
LOWET is offline
post #7 of 7 (permalink) Old 08-02-2010, 10:31 AM Thread Starter
LOWET's Avatar
You are 100 % correct. I removed the liner and it looks beautiful. My entire engine bay is done up in RED and Polished alluminum and with the yellow ujnderside of the hood looking clean and shinney, it really makes the engine bay look unbelieveable
LOWET is offline
Hood liner 04blueskys Service, Maintenance and Technical Discussion 22 07-02-2010 12:03 PM
Do i really need a hood insulator/liner? iwant2buyaGTO Exterior Discussions 3 05-09-2010 10:04 AM
Hood scoop removal Aramz06 2004-2006 GTO General Discussion 3 03-30-2010 10:04 PM
How to remove hood liner retaining pins Vetterss 2004-2006 GTO General Discussion 3 03-21-2010 03:29 PM
