Hood won't open! - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-28-2010, 09:01 PM Thread Starter
Hood won't open!
Hey guys, my hood latch wont work on my 06 GTO. It worked when i got it, and earlier yesterday but when i tried it today it wont pop. When i pull the hood latch handle inside the car it has the normal tension on it but pulls all the way out without popping the hood. Theres tension on the handle and it springs back but wont pop! lol. What do i do?
MikeTheDiabetic is offline
post #2 of 6 (permalink) Old 03-29-2010, 06:04 PM
BWinc's Avatar
push down on the hood and try again?
BWinc is offline
post #3 of 6 (permalink) Old 03-29-2010, 06:19 PM
GM4life's Avatar
Have someone pull the handle while you push and pull on it. When you get it open grease up the stricker, and make sure the spring isn't broken.
GM4life is offline
post #4 of 6 (permalink) Old 03-30-2010, 09:41 AM Thread Starter
UPDATE, i had a buddy push down on the front of the hood while i pulled the handle and it opened. Im assuming that i need to grease up the latches and whatnot. Also should i try adjusting the the tension of the spring? I feel like that could be the problem, to much force pushing up on the hood considering when you relieve the pressure a little bit it opens fine. any suggestions?
post #5 of 6 (permalink) Old 03-30-2010, 09:43 AM
I have a Ford I need to beat on the hood while I pull the handle.
post #6 of 6 (permalink) Old 03-30-2010, 02:26 PM Thread Starter
I would like to stay away from that as much as possible lol. but i gues hey whatever works for ya.
Fuel door won't open!?!?!?! LordAnarchy Service, Maintenance and Technical Discussion 12 07-11-2009 08:29 AM
Open Invitation to Join Us. GTO JUDGE SVGTO Tigers 3 05-08-2008 07:30 PM
Open headers? JTYLER1604 Service, Maintenance and Technical Discussion 2 06-06-2005 08:00 PM
Anybody else Open track their Goat? beertestr 2004-2006 GTO General Discussion 0 10-25-2004 04:25 PM
