How do the Aussies go so fast - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-13-2005, 09:17 PM Thread Starter
rushhour's Avatar
The Aussies have a lot more experience with these cars then we do. The attached thread to Chipmaster will give you guys some ideas as to how they are doing it - Project Monaro. It is extremely informative and gives you both dyno charts & strip times to back up their conclusions. It also kills some "myths" going around in the States as to what the optimal set ups are for NA engines.
Steve
http://www.chipmaster.com.au/
2004 Black, A4, (aka the Black Demon)
390ci AES low compression
PB 1.611, 11.732 @ 115.22, DA +1,973 @ 4,005 lbs
1.566, 11.585 @ 116.22, DA +960 @ 4,010 lbs (Nasty Headwind)
1.538, 11.352 @ 119.16, DA -2,340 @ 3,960 lbs
rushhour is offline
post #2 of 2 (permalink) Old 08-14-2005, 02:03 AM
Giddy up! damn, them Aussies sure know to build a car!!
There was a thread on LS1Tech.com ref cams....apparently they run small duration/tight LSA..i.e..108-110....make ubergobs of torque.
Route 66 is offline
