How loud is rear end whine? - Pontiac GTO Forum
post #1 of 18 (permalink) Old 01-31-2006, 05:00 PM Thread Starter
Is it always really loud or can it be quiet? I think I've heard a soft whistling noise at 45-55ish mph but I sometimes hear tire noise as well which I might mistake for the differential. I took my GTO on a drive with a service manager at the dealership and most of the time he said it was likely tire noise but towards the end of the drive he said he noticed something that might be the characteristic rear end whine. My car is an 05 A4 with ~1200 miles.
SDSU_GTO is offline
post #2 of 18 (permalink) Old 01-31-2006, 06:08 PM
Mine has it a little, 05 m6, between 45-50. No big deal though.
fat nick is offline
post #3 of 18 (permalink) Old 01-31-2006, 06:23 PM
Some guys described a loud whine, some have reported a barely noticeable whine. My whine isn't that bad but it is noticeable. It was noticeable enough for the service manager to verify a new rear was in order. He also told me that another guy was in with one and complained of whine but it was not enough to warrant a replacement.
I don't know if this is true or not, but I was told that GM is tightening their belt on wholesale replacement of rear ends. They are requiring further examinations or other alternatives before replacing.
All I know is my replacement is on a ship headed for the states, and is due in mid Feb.
IMO...if it is true what I am told, I'd suggest getting it taken care of before GM decides not to replace them anymore.
post #4 of 18 (permalink) Old 01-31-2006, 06:28 PM
johnebgoode's Avatar
When it gets to the point where its noticeable, you'll know. I am on my second one and its starting to whine after 300 miles. Back to the Dealer I go.....
It's usually between 48-55mph and only under acceleration.
johnebgoode is offline
post #5 of 18 (permalink) Old 01-31-2006, 07:16 PM
what exactly causes the whine, is there damage inside the rear end or is it really just a normal thing?
HotRodGuy is offline
post #6 of 18 (permalink) Old 02-01-2006, 10:20 PM
cat1055man's Avatar
Here is my best guess..... the root cause is improper gear tooth contact due to an assembly process control problem setting the proper pinion to ring gear engagement and backlash. These settings are critical to obtain quiet gear mesh
2005 GTO, M6, Quicksilver / Black
2003 GTP, Silver / Black, 3.4" Pulley
1994 Z-28, Red, M6, Hotcam, SLPs, Tune
1994 Z-28, Red, M6, stock
1994 Cadillac STS
cat1055man is offline
post #7 of 18 (permalink) Old 02-02-2006, 06:51 AM
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
do it cut the performance or is it just noise?
EEZ GOAT is offline
post #8 of 18 (permalink) Old 02-02-2006, 09:40 PM
cat1055man's Avatar
It's just noise but if it continues to get louder the differential could eventually fail. My second diff. makes a faint whine and I will monitor noise level and go back to the dealer if the noise increases
1994 Cadillac STS
post #9 of 18 (permalink) Old 02-03-2006, 01:30 PM
I just noticed mine last night.. cruising at 50 mph in 6th I could hear it clear as day without the music on.. but only at like 15% throttle (just a guess not an exact measurement people) basically enough to keep the car at a constant speed.. but when I stepped on it a little bit it went away completely or when I let off the gas same thing.. I don't know.. I can deal with that if it doesn't get worse.. besides its a rareity that I'm ever off the gas or not accelerating or that I'm not playing music.. lol..
dizz81 is offline
post #10 of 18 (permalink) Old 02-03-2006, 03:20 PM
derf's Avatar
It doesn't directly affect performance but it results in uneven wear on the gear set and premature failure.
04 QuickSilver - !CAGS, Lingenfelter CAI, 05 Bumper with Stainless Works 04->05 cat back, Power Slot Rotors & Hawk pads.
derf is offline
