How to replace brakes - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-01-2012, 11:46 AM Thread Starter
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
It would be awesome if someone could give me a guide to change brake pads myself. i heard it is rather easy and i was hoping i could do it myself and save some many. would be a huge help!!
Gto-noob is offline
post #2 of 7 (permalink) Old 08-01-2012, 03:23 PM
It's so easy. . . even a cave man could do it. It's been covered many times in many places. Once you do one wheel you'll go "duh". You need a large C clamp or even better yet get a Harbor Freight disc brake kit. You use either to push the caliper pistons back in so you can get the "thicker than used" new pads over the rotors. That, a couple of wrenches and a jack stand
How To Change Your Brake Pads - Edmunds.com
post #3 of 7 (permalink) Old 08-02-2012, 06:20 AM Thread Starter
thanks soo much bro im going to get right on nit
Gto-noob is offline
post #4 of 7 (permalink) Old 10-15-2012, 10:48 PM
So I am in the same boat here finally changing out the brakes. I have an 05. I read that I need to replace the "torque to yield bolts" that hold the calipers in place with new bolts & washers. Is this something that really needs to be replaced every time you remove the calipers or is this just a revenue generating thing?
I am going with DBA 4000 t3 slotted rotors with Hawk HP ceramic pads if that makes a difference.
C'VilleGTO is offline
post #5 of 7 (permalink) Old 10-16-2012, 08:49 AM
6QTS11OZ's Avatar
I've changed out hundreds of pads and never replaced those bolts on any car I've owned or worked on and haven't had any problems in almost 30 years of changing pads.
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
post #6 of 7 (permalink) Old 10-16-2012, 09:18 AM
jpalamar's Avatar
X2. I've never replaced those bolts either.
I do have an OCD issue of cleaning each bolt off with a wire brush and also use a dab of locktite.
04 GTO - sold
jpalamar is offline
post #7 of 7 (permalink) Old 10-16-2012, 09:58 AM
Thanks for your help, time to go to work. I thought it was a little over the top to be replacing them but just wanted to double check.
How do you replace the shifter? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-10-2011 06:23 PM
New car, what all should I replace jpalamar Service, Maintenance and Technical Discussion 23 12-15-2009 04:24 PM
Need to replace headlights jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 11 05-08-2009 12:30 PM
Will this replace gasoline? speedwrenchx10 The Lounge 0 01-09-2008 06:47 PM
Do I need to replace the old dampener? bigcode99 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-02-2007 10:21 PM
