How to validate engine work done to your GTO? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-26-2010, 08:36 AM Thread Starter
I'm hopefully going to get my little goat today from the dealership after having the head gaskets replaced due to faulty transcooler hoses. I really want to do some sort of validation the work was done properly besides just driving off and hoping for the best. I asked to keep all the parts that are being replaced as a step of precaution but I'm still worried about whether the work was worthy of paying nearly $3,000.00 for and done correctly.
I was informed the cylinder head was not warped and that it was machined. I want documentation from the machine shop. I was told all spark plugs were replaced. I want those too. I was also told that all the valves were replaced. Definitely want those back. Thermostat as well among the many parts. I also want the compression test results prior and after. As well engine sensor data.
Of course I'll check the oil and oil filter and coolant. I don't want that. Is there anything else I should look for and is it a good idea to have another mechanic look at the work done? Of course, I'd want somebody who really understands LS engines well. Any suggestions or a checklist of sorts would really be appreciated and useful.
YeomanDroid is offline
post #2 of 6 (permalink) Old 10-26-2010, 09:29 AM
jpalamar's Avatar
You had a bad head gasket. If a machine shop checked it out and the heads weren't warped, what machining was needed? Also not sure why they would replace the valves either.
Getting all your old parts back is def a good idea as well. Something just sounds really fishy.
jpalamar is offline
post #3 of 6 (permalink) Old 10-26-2010, 03:45 PM Thread Starter
I know, it's kind of odd how when I asked for my valves the service advisor went to the parts area and asked about it but couldn't give me an answer. I was mad and while walking out said "I'm definitely going to want them".
post #4 of 6 (permalink) Old 10-26-2010, 07:55 PM
jetstang's Avatar
They aren't stupid, but they are hoping that you are, and you aren't...
They didn't replace the valves, period, they had no reason to replace them. They can get you some old valves from the machine shop, but they aren't yours. Why would your valves be in the "parts area", they should be at the machine shop.
They had no reason to machine the head, the machinist said it wasn't warped, they may have cleaned the surface up with a light grind, but I doubt it.
They are just trying to justify the expense.
They probably did a decent job, remember the mechanic doing the work is not the guy doing the bill. Hopefully the mechanic has some integrity and isn't just after the almighty greenback. I feel for you, the dealership sucks and I would never go back to them again..
Burning rubber since 1982!!
jetstang is offline
post #5 of 6 (permalink) Old 10-26-2010, 09:15 PM
Mike_V's Avatar
Service writers work on commission. If they replaced all that, there will be an invoice they paid. If you don't get your answers or proof, file an online complaing with the BBB then call GM's customer service and start the ball rolling.
Mike_V is offline
post #6 of 6 (permalink) Old 12-29-2010, 02:40 PM
serotonin's Avatar
I used to be a mechanic, about a decade ago. Back when I was, I was told that we were legally required to give the parts (the ones replaced) back if the customer asked. Our policy was to offer it to the customer every time, no matter what.
I'm not sure if that was, or is true, and am not privy to any of that from a legal stand point. This may be something you can research and use to your benefit if it's really true.
I have to agree with Jpalamar, something definitely sounds fishy here; sorry to hear about the hardship
serotonin is offline
Can '670' Heads work on a 1966 389 engine with stock pistons? Ozzie 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 12-27-2009 12:08 PM
internal engine work vs. supercharger dustyminpin 2004-2006 GTO General Discussion 10 07-16-2007 10:01 AM
68 GTO headlights- how do they work? GTO394 1964-1974 Tempest, Lemans & GTO General Discussion 2 08-21-2006 08:51 PM
GTO Paint Work lotaguts Exterior Discussions 17 02-26-2006 04:48 PM
[Freebies] How they work, why they work & how to work them. Last The Lounge 1 01-09-2005 07:15 PM
