Hrs install A/C Liquid Line Dryer to Evaporator - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-24-2015, 02:59 PM Thread Starter
Hello GTO Members:
How much hours to lower engine & cradle down and possible remove intake manifold so that A/C liquid line from Dryer to Evaporator can be replaced?
All the hoses, wires, computer, steering column also has to be disconnected or removed also.
Just wondering if labor cost is worth it, but I didn't want mechanic to stress the aluminum line when installing if the above is not moved out of the way and, thus, a tight force fit?
Aloha,
Eric
Eric Sakai is offline
post #2 of 2 (permalink) Old 03-01-2015, 11:28 AM
Doing it like that would be a lot of labor plus you'd have to figure out a way to replace the cradle bolts. They are one time use bolts and are no longer available. i saw one fix of getting the proper threaded rod and putting nuts on, then the cradle have to be properly aligned too. I would guess it would take a whole day at least
Brake line install zzomby 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 10-21-2012 11:37 AM
Fuel Line Install with Body on jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2012 10:59 PM
liquid spraying under the hood HELP!!! FIRELIFE25 Service, Maintenance and Technical Discussion 2 10-08-2010 04:38 PM
