I think I broke my T-56 - Pontiac GTO Forum
post #1 of 18 (permalink) Old 08-03-2007, 09:19 PM Thread Starter
CycloneJack's Avatar
Send a message via AIM to CycloneJack
I've never had any problems with my transmission for the 4 months I've had it, never. I'm the original owner and its now got about 4500 on it. On my drive to work (which is about 5 miles) my car was fine, until I pulled into the parking lot and it didn't want to go into second or first. I thought it was just acting up for no reason so I forgot about it until I left. Then when I left work, I couldn't get it into reverse. I had to roll backwards out of my spot to get out. Now, none of the gears are easy to get into and 5th is very bad and reverse is nearly impossible. 6th made a slight grinding noise with the clutch all the way to the floor. I'm thinking of briging it to a dealer tomorrow to look at it but I'm curious about my warranty. Does my Corsa exhaust void it at all? If it doesn't and they say it does should I fight it? Also, I know GM is tight with loaning cars to people who aren't 23. I'm only 20 and I don't know if they'll give me a loaner while my car is in the shop. I'm sure they'll give me a sunfire or something with a million miles on it if they do. I just want to know what to expect when I go in tomorrow.
CycloneJack is offline
post #2 of 18 (permalink) Old 08-03-2007, 10:25 PM
Exhaust will not void the transmission warranty.
abright52 is offline
post #3 of 18 (permalink) Old 08-03-2007, 10:32 PM
I don't know, but it sounds like a sticky clutch, keeping the gears loaded down with engine torque.
Good 2 go is offline
post #4 of 18 (permalink) Old 08-03-2007, 10:33 PM Thread Starter
I just wanted to be completely sure because a cold air intake voided my friends warranty on his Golf GTI. They said the intake made the car more powerful and the transmission couldn't handle the extra power. I know that's completely b.s. but it shows that anything is possible.
post #5 of 18 (permalink) Old 08-03-2007, 10:59 PM
b_a_betterperson's Avatar
Exhaust has absolutely nothing to do with the transmission. However, it could lead the service writer to say "oh, a gear head busted up his tranny" and rule that it's not a warranty claim because they can make more money charging you for it.
As for a VW dealer voiding a warranty because of a CAI, that's normal because every VW dealer on the face of the Earth is run by complete a-holes.
Correct me if I'm wrong -- but isn't Dundee in the Chicago area? You might want to ask around if there are any good, performance friendly Pontiac service departments in your area.
I have heard that Crystal Lake is mod car friendly, Dan Wolf and Haggerty are good while Schaumburg and Sullivan are horrible.
b_a_betterperson is offline
post #6 of 18 (permalink) Old 08-04-2007, 06:32 AM Thread Starter
I am near the chicago area. I'm def. not going to schaumburg because they are the people I first went to to buy the car and they were the absolute worst people to deal with. I would like to take it to the place I bought it, but they were bought out by somebody else a month ago and they are an hour away. As far as near me, Woody Pontiac in Elgin was where I planned on taking it because they were the dealer of choice for a friend of mine and they seem fine. I will consider the Crystal Lake dealer though. I'm just worried because they have to remove my exhaust to get the trans out and I don't wan them saying "Oh, we don't know how to remove aftermarket exhaust, we can't do it". Although I guess that's why I should find the performance oriented dealer. Also, I can't just bring it to any GM dealer can I? When I had an Oldsmobile Aurora, I'd take it to the Chevy/Cadillac dealer near me since Olds was gone and it had a Northstar so I figured Cadillac guys would know what to do.
post #7 of 18 (permalink) Old 08-04-2007, 07:11 AM
The_Goat's Avatar
If it's a big deal up in the Chicago area, you can always come down to Bloomington to Rebec - Pontiac. I've got a CAI and modified exhaust and I've never had a bit of trouble from them on any warranty work.
The_Goat is offline
post #8 of 18 (permalink) Old 08-04-2007, 08:35 AM
unless they find a direct link between the exhaust and the trans problem you are having they should fix it. performance parts should only void a warranty claim if they directy cause the problem. likea turbo blowing the engine as opposed to a window motor going bad. turbo had nothing to do with it. you should be ok.
cpowell is offline
post #9 of 18 (permalink) Old 08-04-2007, 09:03 AM
Check your clutch's slave cylinder. You still have fluid? The pedal feel the same? If every thing there is fine, Maybe the gear oil in there is leaking? Check the plug for evidence of leakage. Linkage to the transmission tampered with at all?
Grinding sounds like synchronizer gears? Hope you don't have the problems 2005_GTO_Girl had. Fingers crossed.
post #10 of 18 (permalink) Old 08-04-2007, 12:50 PM
fergyflyer's Avatar
The darn crappy T-56 is the main reason I bought an A6 in the C6. If they would have had another tranny, something with decent shift feel and reliability, I would have bought a manual.
fergyflyer is offline
