Identifying whistling noise - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-11-2015, 06:35 PM Thread Starter
dave1's Avatar
I have a 06 GTO I've only had a few months, the car has about 76,000 miles on it. I notice when I start the car and its running there is kind of a squeak/whistling noise. I cant tell if its a belt or pulley, or could it be the water pump? I have no loss of coolant and the only seepage I see is from the radiator cap, which I will replace. Should I go ahead and replace the water pump? and is that something my local NAPA store can order for me? Thanks
dave1 is offline
post #2 of 8 (permalink) Old 07-11-2015, 06:43 PM
Its probably belt, tensioner or idler. Don't think its pump. If you have to replace the pump the local stores have the pump and stat in stock and its easy to change. Btw both mine and my budys water pumps started leaking at similar milleage.
Qnko is offline
post #3 of 8 (permalink) Old 07-11-2015, 09:38 PM
Badkat's Avatar
My money is on belt or belt tensioner as well. The stock tensioner has a tendency to make a weird grinding or whistling noise.
Start the car and gently spray a little PB-50 Blaster All Purpose Lubricant on the belt tensioner where it spins on the spindle. DO NOT SPRAY THE BELT. Should quiet right up. If that is the original belt, definately replace as well.
Mark - Plainfield, IL http://markquitterracing.com
2004 GTO A4 - LS1
Competition Cam
JBA LTH
K&N CAI
Yank 3600 Stall Speed
Flow Master exhaust
Dyno Tuned
Whiteline Suspension upgrades
B&G Lowering springs
Badkat is offline
post #4 of 8 (permalink) Old 07-11-2015, 10:03 PM Thread Starter
dave1's Avatar
Thanks for the replies guys, I appreciate it
dave1 is offline
post #5 of 8 (permalink) Old 07-12-2015, 09:39 PM
Badkat's Avatar
Don't thank us yet. Only helps if that was indeed what was making the noise, lol. Doubt its the water pump. Water pumps have 2 modes.....they either work, or they don't. If they don't, 99.9% of the time they are dripping or leaking. You said yours isn't leaking, so just deducted it down to belt noise.
2004 GTO A4 - LS1
Competition Cam
JBA LTH
K&N CAI
Flow Master exhaust
Dyno Tuned
Badkat is offline
post #6 of 8 (permalink) Old 07-15-2015, 08:10 AM
Just from reading your subject title, I was going to suggest your windshield wipers. Some windshield wipers have holes in the mounting brackets, and while driving they tend to make a whistling sound...
So, with that NOT being the issue...
Take a few minutes out of your day if possible, and stop by a friendly neighborhood mechanic, pop the hood, and see what you guys can come up with.
My next suggestion, would also be the belt tensioner.
Keep us updated on your problem, and if you're able to solve it.
2006 GTO, Cyclone Grey
Mods: Magnaflow Exhaust
Forum Poster is offline
post #7 of 8 (permalink) Old 07-15-2015, 08:33 AM
AlaGreyGoat's Avatar
It's been brought up over the years that the alternator can make a whistling noise.
Larry
AlaGreyGoat is online now
post #8 of 8 (permalink) Old 07-15-2015, 11:05 AM Thread Starter
dave1's Avatar
This sound is only on start up a high pitched squeak, I'm going to replace belt/tensioner
dave1 is offline
Help identifying Tranny? FireFox3434 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-08-2014 08:49 PM
Need help identifying something. JESchulte 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-15-2012 08:32 PM
Whistling noise when starting up car? rmd83082 Service, Maintenance and Technical Discussion 3 10-21-2011 12:22 PM
Identifying this engine? rnldmdmb 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 08-28-2009 08:43 AM
05 GTO whistling noise from engine BLACK05GTO Service, Maintenance and Technical Discussion 23 01-02-2007 07:58 PM
