Ignition - Pontiac GTO Forum
post #1 of 8 (permalink) Old 05-25-2010, 09:33 PM Thread Starter
Ignition
Has anyone had trouble with their ignition locking up, this will be my second time having to take to the dealership. Only this time i couldn't start car this time and had to have towed.
DBrac3737 is offline
post #2 of 8 (permalink) Old 05-25-2010, 11:15 PM
Had it happen to me at 32000 miles, two weeks after I got the car. Think I'll make sure it gets lubed often. Dealer said it was a common problem.
johnasaurus is offline
post #3 of 8 (permalink) Old 05-25-2010, 11:28 PM
jetstang's Avatar
What part are you talking about? Interesting..
Burning rubber since 1982!!
jetstang is offline
post #4 of 8 (permalink) Old 05-26-2010, 06:49 AM
jpalamar's Avatar
I've seen several threads about this before. I bet using some graphite lube here and there would help alot. I used it on my bike all the time.
jpalamar is offline
post #5 of 8 (permalink) Old 05-26-2010, 07:46 AM
GM4life's Avatar
You have to disassemble the lock cylinder, and use general purpose grease. Thats what I did and have not had a problem for two years. I may have posted instructions on here, if not I can look them up and post it again.
When I took mine to the dealer, they said it was the key made me a new one, called it good and kicked me out the door.
GM4life is offline
post #6 of 8 (permalink) Old 05-26-2010, 10:56 PM
87GN06GTO07IRL's Avatar
^^^ this
87GN06GTO07IRL is offline
post #7 of 8 (permalink) Old 05-27-2010, 07:48 AM
GM4life's Avatar
Graphite does nothing for the cylinder, its used for the tumblers. Been there done that.
GM4life is offline
post #8 of 8 (permalink) Old 05-27-2010, 08:32 AM
Okay, but aren't the tumblers IN the cylinder??
Ignition Lock up CharlieZ 2004-2006 GTO General Discussion 14 05-20-2011 06:03 AM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-25-2009 11:58 PM
ignition question busaben 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-09-2008 09:50 PM
ignition amplifiers AlanSr Engine Discussions 3 07-31-2008 12:11 PM
Ignition Question jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-02-2007 11:31 AM
