ignition coil replacement - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-09-2010, 07:35 AM Thread Starter
I have 3 bad ignition coils...i replaced those 3 but still encounter the same problem should I just replace em all and get new plugs?
BLUE04 is offline
post #2 of 5 (permalink) Old 12-11-2010, 09:32 AM
RJ_05GTO's Avatar
How did you determine that they were bad?
05 GTO A4- Svede otrcai, Fast 102, Livernois stg 2 ported heads, Texas Speed 224R cam, Pacesetter LT's, Edge 3000 stall, Kooks afterburners, Pedders 0 drp rear springs and shocks, MT et streets, 418rwhp/391rwtq, [email protected]
RJ_05GTO is offline
post #3 of 5 (permalink) Old 12-13-2010, 07:20 AM Thread Starter
I took it to the local pontiac dealership and they hooked it up
BLUE04 is offline
post #4 of 5 (permalink) Old 12-13-2010, 11:10 AM
is there an easy way to check if there faulty
lingenfelter cai, vararam tb spacer, v/max ported tb, livernoise stage 2 heads with comp cam 232/232/.50 114 lsa. slp 1 3/4 headers high flow cats, x pipe, qtp cut outs, flowmaster mufflers. tuned by tt performance , highly recomended in n.j.
NEXSTAR7 is offline
post #5 of 5 (permalink) Old 12-15-2010, 03:37 AM
87GN06GTO07IRL's Avatar
Sounds like you have a problem other than coils. I'd get my money back for those and put the old ones back on.
87GN06GTO07IRL is offline
ignition key lock replacement assy.. SKIDLOADER10 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-04-2010 07:54 AM
Ignition Lock Cylinder Removal & Replacement GM4life Interior Discussions 3 08-22-2010 04:24 PM
67 Ignition Coil Location rollyman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 05-15-2007 02:54 PM
