Ignition Cylinder? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 07-07-2012, 06:50 AM Thread Starter
Zulu's Avatar
Ignition Cylinder?
Why is there no sticky topic for this?
Anyway....this is apparently a huge problem for these cars, cuz GM is too cheap to use high grade material in the ignition cylinder and so they lock up in the heat, etc....old problem I'm sure to people who've owned GTOs since 04, but....sticky it anyway.
2006 Pontiac GTO M6
Zulu is offline
post #2 of 13 (permalink) Old 07-07-2012, 07:54 AM
HP11's Avatar
Quoted: 24 Post(s)
Problem? Yes. Huge problem? No. It does happen, however. I've owned mine for about 4 years and know several other that have owned theirs for some time without having this problem. Kind of like the seat stitching.
HP11 is online now
post #3 of 13 (permalink) Old 07-27-2012, 09:45 PM
My just locked up today for the second time. The first time occurred about 3 years ago. I plan on following the Sticky on the first page and fix it myself.
Can our ignitions be replaced with some type of mechanical push button start switch? For example, holding a (hidden)button with one hand and then flipping a toggle switch.
'05 Imp Metallic Blue M6, Magnaflow w/X-pipe, JBA shorty headers, CAGS/skip-shift eliminator
Zebra is offline
post #4 of 13 (permalink) Old 07-27-2012, 10:04 PM
Maybe a keyless push button start...do a search
Dishphead is offline
post #5 of 13 (permalink) Old 07-27-2012, 10:51 PM
I am unable to removed my ignition cylinder...advice please.
My steering is in the locked position, column cover removed.
I insert key, push down in the little hole with an allen wrench. I can feel the little tab depress but the cylinder doesn't pop out and I am unable to pull it out.
Zebra is offline
post #6 of 13 (permalink) Old 07-28-2012, 08:54 AM
HP11's Avatar
Quoted: 24 Post(s)
Have you seen this?:
2004 - 2006 GTO Ignition Cylinder Replacement - YouTube
HP11 is online now
post #7 of 13 (permalink) Old 07-28-2012, 09:54 AM
I was to removed the cylinder by whacking it. I used a rubber mallet and a hammer. I placed the wooden handle on the keyhole and whack the hammer with the mallet. I was then able to unlock my steering wheel and turn the key to the ON position. From there I followed the YouTube video instructions and removed the ignition cylinder.
Upon inspection, the "problem area" did not seem to have as much wear as many of the photos have shown. When I was disassembling the cylinder a extremely small spring and small silver metal piece dropped out. The metal piece is similar to a Micro SD card. It's not a tumbler because they are brass/yellow colored. The metal piece seems to operate by sliding on a spiral ramp. It was located on the bottome near the keyhole end of the cylinder. I re-assembled the ignition cylinder without the spring and small metal piece.
It seems to work fine and seems much easier to insert and remove the key.
Zebra is offline
post #8 of 13 (permalink) Old 07-28-2012, 02:16 PM
Justinwagner's Avatar
How do I get it to unlock in the heat?
Sent from my SGH-T959V using AutoGuide.Com Free App
Justinwagner is offline
post #9 of 13 (permalink) Old 07-28-2012, 05:37 PM
Justinwagner,
I left my car along and let it set overnight and began working on it first thing in the morning. Whacking the ignition cylinder while it was still hot outside may have worked. I had to whack it fairly hard. I would hit it then tried to turn the key and repeated only a 3 or 4 times and then the key turned. The whacks must have jarred the "problem pin" enough for me to able to turn the key.
Zebra is offline
post #10 of 13 (permalink) Old 07-28-2012, 05:43 PM
Zebra,
Ok thanks man but what do you mean by whacking? Like hitting the end of the key? Also my steering wheel is locked will whacking the key also help with this problem?
Need Ignition Lock Cylinder for my 04 GTO Eraldlula17 2004-2006 GTO General Discussion 1 01-04-2012 07:40 PM
Ignition Lock Cylinder goatcrazy88 Service, Maintenance and Technical Discussion 15 07-08-2011 04:33 PM
Ignition cylinder PisnNapalm 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-30-2010 07:44 PM
remove ignition cylinder with no key????? crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-17-2009 05:23 AM
ignition cylinder killer quad 2004-2006 GTO General Discussion 4 08-08-2007 01:58 AM
