Ignition problem - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-06-2019, 03:27 PM Thread Starter
Cdidy97's Avatar
Ignition problem
Hey guys. My 04 GTO sometimes just clicks when I try and start it. I can turn it off and it usually will crank. Sometimes it takes a few time of doing this. Any suggestions?
Cdidy97 is offline
post #2 of 4 (permalink) Old 07-07-2019, 03:57 AM
AlaGreyGoat's Avatar
Are the clicks coming from the starter?
If so, it is probably the starter solenoid.
Replace the starter.
If not, have it scanned for codes.
Larry
AlaGreyGoat is online now
post #3 of 4 (permalink) Old 07-07-2019, 09:03 AM
Lemans guy's Avatar
Quoted: 54 Post(s)
Agree, classic symptoms of bad starter solenoid. Check battery voltage and connections at battery as well, but most likely solenoid.
Lemans guy is online now
post #4 of 4 (permalink) Old 07-11-2019, 12:50 AM
designerron's Avatar
I sometimes have the same problem. If I take the key out, turn it over and put it back in, it starts. As long as that keeps working, I'm not pulling the starter out. Maybe something to do with the ignition switch and/or the security system. Here's a link to what I found when researching the problem:
https://www.cargurus.com/Cars/Discussion-t9410_ds487702
designerron is offline
