Ignition/starting problem 69 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-16-2013, 06:10 AM Thread Starter
I went to start my 69 GTO (4 sp manuel transmission) the other evening. It usually doesn't start on the first try if it has been sitting a while. It turned over fine. ON second try the key would not advance to the start position.
I had the trans in reverse with the clutch disengaged. The lights came on
but the key just wouldn't go to start. I tried wiggling it and taking it in and
out several times. Also shifted trans to all gears. Still nothing. I figured the
ignition cylinder went bad since it is the original one. Cheapest fix would be a new ignition key cylinder. Removed steering wheel and turn signal assembly. Found two slots in the upper right hand side of column I thought would be the location of the cylinder release. Broke through the covering with a small screw driver. I probed those slots for a half hour and could feel nothing that resembled a release. Any one have a similar problem with the ignition and any suggestions on getting the cylinder
out? Thanks J R
Soups is offline
post #2 of 4 (permalink) Old 06-16-2013, 08:15 PM
jmt455's Avatar
Ignore the first response in this thread; scroll down and you'll find the correct instructions.
No KEY need help to get cylinder out - Nova Tech
It's a Nova site and they are discussing a 1970, but the switch installation and removal is the same as your car.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 4 (permalink) Old 06-17-2013, 05:38 AM Thread Starter
Thanks for the info, I have been trying with a very thin piece of metal to
release the cylinder. I know what slot to go in (the real narrow one) I can
actually feel the release going down but the cylinder only moves out about a
quarter of an inch or so. For some reason it is not fully releasing. Anyway after more research I am finding out that the ignition SWITCH may be the culprit as to why the key will not go in to start position. I understand the
spring action for releasing the key in start position is inside the Ignition switch I would like to check the mechanism behind the key cylinder as well while it is all apart.
Soups is offline
post #4 of 4 (permalink) Old 06-17-2013, 05:46 AM Thread Starter
spring action for releasing the key in start position is inside the Ignition switch. I would like to check the mechanism behind the key cylinder as well while it is all apart.
Soups is offline
70 GTO - Ignition Problem?? 1970GOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 07-17-2011 08:43 PM
06 GTO Starting problem jeffsgto Service, Maintenance and Technical Discussion 7 01-05-2011 12:27 PM
New GTO, Starting problem! 20GTO04 Service, Maintenance and Technical Discussion 5 12-16-2010 04:21 PM
starting problem!! trevee 2004-2006 GTO General Discussion 9 05-29-2010 10:59 PM
Starting Problem MAXEPR Service, Maintenance and Technical Discussion 6 09-27-2009 03:36 PM
