Info. Seat Movement ? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-01-2005, 11:55 PM Thread Starter
Been said the 06 seats move faster in order get in the back seat easier ? Does anyone know if the fix is different motors , or gear ratios ? I sure would like a little faster movemt~~~ If it was just motors it might be an easy mod ??
oyle is offline
post #2 of 4 (permalink) Old 12-02-2005, 08:11 AM
Hi Oyle,
It's a little more than that. There is a new track and motor assembly for '06. The motor probably has a different gear but you also need to change the track the gear runs on so the teeth numbers match. It's not a cheap swap either unless you wait until the junk yard gets some in (hopefully not mine)!
edysinger is offline
post #3 of 4 (permalink) Old 12-02-2005, 08:18 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
good to know! I also thought it was just a motor/gear swap.
post #4 of 4 (permalink) Old 12-02-2005, 12:11 PM Thread Starter
I figgered they'ed make it difficult ~~~ so much for that . Thanks
oyle is offline
