Installing Bushings / SLP Swaybar Labor? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-31-2005, 10:26 AM Thread Starter
I'm planning on swapping out all rubber bushings on the Goat with Polyurethane ones--- I did that on my Bimmer and it made a HUGE difference-- I loved it.
I also want to get the SLP rear swaybar (which comes with polyurethanes)...
Question-- how big of a deal is it to swap the bushings out and install the swaybar?? Since it probably takes special pressing tools etc...and I have very little free time, I probably will want it done by a local shop. How much labor do you think is reasonable to perform the above?
Groucho is offline
post #2 of 4 (permalink) Old 03-31-2005, 10:53 AM
I'll ask the techs on the bushings, but I know its pretty involved installing the rear sway bar(you have to drop the rear subframe to get to it) we charge 2 hrs to do it at the dealership (keep in mind we have lifts - it helps) I'm sure the bushings are going to require the use of a press. I'll find out...
GTODEALER is offline
post #3 of 4 (permalink) Old 03-31-2005, 11:18 AM
i was wondering the same thing. can the 04 sway bar and bushings fit the 05? i would think so, there not that much different, but i did not want to spend the money and find out that they do not work.
ouijaguy is offline
post #4 of 4 (permalink) Old 03-31-2005, 11:33 AM Thread Starter
Here's a decent article on it.
http://gmhightechperformance.com/tech/0503htp_gto/
Looks fairly nightmarish to install. I'm farming it out.
Groucho is offline
