I've got a problem... - Pontiac GTO Forum
post #1 of 12 (permalink) Old 10-31-2006, 01:53 PM Thread Starter
Justice's Avatar
Send a message via Yahoo to Justice
I've got an 04 M6. Sometimes, but not all the time, I can be driving down a road and my steering wheel will "shake". I've noted that going down the same strip of road does not make a difference. Sometimes it will shake, other times it won't. Also, sometimes when I brake the steering wheel shakes a little, and there's no pulsing from the pedal.
I just had the car aligned 3 months ago. Any suggestions?
"Some people are like slinky's. They really have no useful purpose, but they can still put a smile on your face when you push them down stairs."
Justice is offline
post #2 of 12 (permalink) Old 10-31-2006, 02:06 PM
Odd. I would check toe and rotor warp. But it doesnt sound like that would explain it. Good luck
bg2m8o is offline
post #3 of 12 (permalink) Old 10-31-2006, 02:26 PM
b_a_betterperson's Avatar
I've been chasing that problem ever since aftermarket wheels and tires were put on my '04.
Turns out the Falken tires were out of round. Tire store mounted something like 10 of them before they found four good ones. Turns out one still vibrated a bit because the welds on my custom wheels were done by hand -- an inherent weakness in the design.
Got rid of the Falkens and replaced with General Exclaim UHPs. Cleared up 99% of the problem. The rest is from the *()&^))*&%)( wheels.
I'd stay after the alignment. Screw the roadforce balancing and all that other stuff. In my case, the only thing that did was lighten my wallet.
b_a_betterperson is offline
post #4 of 12 (permalink) Old 10-31-2006, 04:19 PM
GTO4ART's Avatar
Same Problem...
I believe it is an issue of rotors being out of round. It is hard to fully accept because it happens intermintantly, but I started having the problem after having to bring my GTO to a quick stop from a pretty high speed. Before the incident there was no shaking in the wheel whatsoever. One thing you could do that wouldn't be costly is put a dial indicator to the rotors and see if they out of round. I hope to do this soon...I'll keep you guys posted.
GTO4ART is offline
post #5 of 12 (permalink) Old 10-31-2006, 04:33 PM
anmracing's Avatar
For the sweet sound of power,
anmracing is offline
post #6 of 12 (permalink) Old 10-31-2006, 07:04 PM
I have an 04 and had the exact same problems I thought it was my alignment but they checked rotors, and they were out of round. I just got a new set today. but then i get my car back and notice a two deep scratches on my driver door (like someone keyed it or dropped a tool against it.) and of course they said they didn't do it!!!
vandersgoat is offline
post #7 of 12 (permalink) Old 11-01-2006, 01:29 AM Thread Starter
Justice's Avatar
Is an out of round rotor a manufacturer defect?
Justice is offline
post #8 of 12 (permalink) Old 11-01-2006, 12:04 PM
Sometimes - but usually not. A warp usually occurs when a really hot rotor is cooled too quickly. A panic (real panicky) stop on a rainy day can cause it. Or driving through a deep puddle when the brakes are hot is not good either. In some cases where the rotor is just a piece of junk, hard use can bend em too.
bg2m8o is offline
post #9 of 12 (permalink) Old 11-01-2006, 12:53 PM
Can it be machined when that happens? Or is it a whole replacement type deal?
Go Dog Go is offline
post #10 of 12 (permalink) Old 11-01-2006, 01:01 PM
The rotors can usually be machined so long as once they have been trued up, they do not exceed the minimum thickness specified for the piece. This spec is usually stamped right on the rotor.
Problems usually get worse after machining because the rotor is now thinner than before, and may be more prone to warping given that it there is less metal there. I usually change rotors with pads when I do (or have done) a brake job. Buy HIGH quality OEM pieces or from a vendor like Akebono, PBR etc. I never ever ever ever skimp on brakes. Not ever.
bg2m8o is offline
