Just got a 2005 GTO with some interesting issues - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-13-2013, 11:53 PM Thread Starter
I'm kind of wondering if anyone else has ran into this, first off the car runs great, and I couldn't be more pleased but I ran into this issue even driving it home from the dealer and I'm a bit baffled. The issue is the Traction control and Cruise control, sometimes they work, sometimes they don't, this happened from the very beginning, since then I got a new key and after first I thought that somehow was the issue because it worked for about a day, but now it is back to the old tricks. Here is what happens:
When I turn on the car, the system check runs and once it is complete, if the Traction Control starts in the "off" mode, I can't turn it back on and the Cruise control will turn on but not "set" If the Traction control starts in the "on" mode, everything will work fine. I'm not sure if this might be from some aftermarket mod, a weak battery(yes mine is and will be replaced soon) or something else. Any suggestions would be awesome.
HBL Oak is offline
post #2 of 5 (permalink) Old 07-14-2013, 06:36 AM
trues607's Avatar
Every time I start my '04 the traction control is always on. There might be a mod or maybe a problem.
trues607 is offline
post #3 of 5 (permalink) Old 07-19-2013, 11:03 PM Thread Starter
I'm thinking mod...
More testing is required, but it seems if I shut the stereo off(after market stereo) before I shut it down, when I light it up everything is fine, I'm wondering if it has anything to do with the bluetooth feature?
HBL Oak is offline
post #4 of 5 (permalink) Old 07-20-2013, 09:13 AM
markpetersonii's Avatar
Send a message via AIM to markpetersonii
Well, I used to have that problem and it progressed into myself having to get a new computer for the car.
It started with the TC not working, went to the A/C not working, to the RPMs jumping at idle to the car being completely dead.
If any of that happens, in that order or out of that order and none of the other problems fix themselves. It might be your computer.
Sent from AutoGuide.com App
MAP2 Photography
2004 Pontiac GTO
2003 Mercedes Benz E500 Sport
markpetersonii is offline
post #5 of 5 (permalink) Old 07-22-2013, 07:46 AM
BWinc's Avatar
If it is the ECM, hope you have the security card with all the codes.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
2005 rear end issues nomiss05 Drive train, suspension, alignment and brakes. 5 07-21-2012 11:41 PM
2005 issues 2005_GTO_Girl 2004-2006 GTO General Discussion 21 06-02-2007 11:38 AM
interesting find on the diablo tuner for the 2006 gto j3157 Engine Discussions 0 04-12-2007 10:30 PM
Interesting M6 Transmission Problem - 05 GTO cscotti Drive train, suspension, alignment and brakes. 19 03-12-2006 09:15 PM
here's an interesting question for you GTO guys... powder 2004-2006 GTO General Discussion 9 10-26-2004 09:30 PM
