Key fob - Pontiac GTO Forum
post #1 of 37 (permalink) Old 09-26-2008, 03:13 PM Thread Starter
wkendtoy's Avatar
Key fob
I think the battery is going out on my key fob, so I went in to the dealer to inquire about it. I know you can't change the battery in them unless you want to break it. The key fob alone is $64 without the key. Then they wanted $150 service charge just to reprogram the computer for the fob. I ordered a fob, but told them that they could stick the service charge where the sun doesn't shine. Does anyone know how to reprogram the thing?
WTF!! $150 charge to program the key. There has to be an easier way.
wkendtoy is offline
post #2 of 37 (permalink) Old 09-26-2008, 03:27 PM
I believe you will need your ignition key code, and your BCM code so you can hook up the gizmo to the computer and program the new key fob to the BCM.
post #3 of 37 (permalink) Old 09-27-2008, 08:47 AM
GM4life's Avatar
Yes there is an easier way it takes about 30 minuits, I've done it. Bear with me its been awile sence I've done it. Put the key in the ignition, turn to the on position(do not start the car)the car will honk once or three times after 10mins. Turn the key in the off position, then turn it back on for another 10 mins the car will honk twice. Turn it back off and back on for 10 mins the car will honk either once or three times, then turn it off and try to start the car. I'm going to try to find the proceadure and post it up.
GM4life is offline
post #4 of 37 (permalink) Old 09-27-2008, 08:51 AM
GM4life's Avatar
Ahh found it.
Transmitter Programming
The transmitter may not communicate with the receiver if any of the following situations occurs:
The transmitter battery wears down.
The transmitter key has been replaced.
The Body Control Module (BCM) has been replaced.
Perform the synchronizing procedure if the transmitter does not communicate with the receiver. If the transmitter and/or receiver are replaced, preform the following programming procedure:
Programming Transmitters With Tech 2
Important
It is not possible to program a remote transmitter without the Body Control Module (BCM) security code. The security code is contained on the Important Security Information Card issued with the vehicle when new.
Using the Tech 2, select Body / Programming / Program Remote Key and follow the instructions.
Enter the security code when prompted and follow the instructions.
Programming Transmitters Without Tech 2
Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp 3 times.
Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
Turn the ignition to OFF and remove the key from the ignition switch.
Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
GM4life is offline
post #5 of 37 (permalink) Old 09-27-2008, 08:51 AM
That would be great....
If you find it, start a new thread on it and I will make it a sticky. Great info to share.
post #6 of 37 (permalink) Old 09-27-2008, 08:53 AM
GM4life's Avatar
Saw your post too late. Ok sir will do.
GM4life is offline
post #7 of 37 (permalink) Old 09-27-2008, 09:04 AM
Thanks GM!!
post #8 of 37 (permalink) Old 09-27-2008, 09:23 AM
SloTymer's Avatar
Changing the battery in the key fob was done successfully by one of our members about a year ago. Look for the post and you will see that it can be done.
SloTymer is offline
post #9 of 37 (permalink) Old 09-27-2008, 09:51 AM
alsgto04's Avatar
Good looking out -- gm4life.
alsgto04 is offline
post #10 of 37 (permalink) Old 09-27-2008, 01:28 PM
GM4life's Avatar
Thanks GM!!
Anytime thats what I'm here for.
GM4life is offline
broken key koman 2004-2006 GTO General Discussion 15 06-26-2008 12:14 PM
Remote Code Key & Theft Deterrent System GM4life Service, Maintenance and Technical Discussion 0 06-14-2008 11:13 PM
Remote key door lock failed DAH GTO Interior Discussions 3 10-25-2006 05:15 PM
What To do about the GTO car key? (Flip open MOD?) twolf 2004-2006 GTO General Discussion 12 02-12-2005 10:25 AM
