Key FOB Transmitter Programming - Pontiac GTO Forum
post #1 of 1 (permalink) Old 09-27-2008, 10:00 AM Thread Starter
GM4life's Avatar
The transmitter may not communicate with the receiver if any of the following situations occurs:
- The transmitter battery wears down.
- The transmitter key has been replaced.
- The Body Control Module (BCM) has been replaced.
Perform the synchronizing procedure if the transmitter does not communicate with the receiver. If the transmitter and/or receiver are replaced, preform the following programming procedure:
Programming Transmitters Without Tech 2
- Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
- After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
- Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
- Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp 3 times.
- Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
- Turn the ignition to OFF and remove the key from the ignition switch.
- Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
GM4life is offline
Closed Thread
Key fob wkendtoy Service, Maintenance and Technical Discussion 36 11-29-2015 03:39 PM
Lost Codes Seattle GTO 2004-2006 GTO General Discussion 33 07-21-2009 02:24 PM
broken key koman 2004-2006 GTO General Discussion 15 06-26-2008 01:14 PM
Remote Code Key & Theft Deterrent System GM4life Service, Maintenance and Technical Discussion 0 06-15-2008 12:13 AM
What To do about the GTO car key? (Flip open MOD?) twolf 2004-2006 GTO General Discussion 12 02-12-2005 11:25 AM
